• 22.11.2026, 22:12
Leonix
Question about recording firmware in new processor AE5
jeudi 12 décembre 2013, 14:54
Bought this wonderful device the last year.
Used to control fans only. Two weeks ago suddenly was lost connection with the windows program, and all fans have stopped :( . Turn off/on power and fans did't help.
In the analysis of problems became clear, that burned down CPU MCF51JM128VLK (basked voltage regulator L0RA, and it's ok with are disconnected Vdd pins of CPU, the multimeter showed resistance 70 Ohm between Vdd-Vss).
I want to buy a new processor and recording firmware. It is real or not? ?(
vendredi 13 décembre 2013, 08:12
You cannot program the frimware on a blank controller.
Leonix
vendredi 13 décembre 2013, 09:32
Why??? Even with using programming device? Or is it due to the "Security circuitry to prevent unauthorized access to RAM and flash contents"?
vendredi 13 décembre 2013, 10:47
The firmware for programming the complete device is not public.
Leonix
vendredi 13 décembre 2013, 12:22
So, can I do something to restore normal working of Aquaero 5 in my case? Or device for 130€ must go to recycle...
Can I order a new microcontroller with program only?
Ce message a été modifié 1 fois. Dernière modification effectuée par "Leonix" (13 décembre 2013, 21:05)
