• 22.11.2026, 21:01
paulstung
how to use than fan control of the LT
lundi 20 janvier 2014, 04:27
I've just bought the Aquaero 5 Lt mainly for the fan control, but how does it work ? I have installed the latest Aquasuite software, but there are no fan options. I have the unit plugged into a molex for power, the USB connector plugged into the motherboard, and the 4 pin signal cable plugged into the motherboards CPU 1 fan header. Please help my pc sounds like a turbine...
lundi 20 janvier 2014, 04:42
4pin? Not a 3 Pin? To Tacho(RPM)?
Ce message a été modifié 1 fois. Dernière modification effectuée par "EnigmaG" (20 janvier 2014, 06:00)
lundi 20 janvier 2014, 07:16
Please disconnect your aquaero befor you damage it!
Take a look to the deatailed Manual at:
http://aquacomputer.de/handbuecher.html
