• 06.10.2026, 15:33
huanghetv
My water cooling with AQ6Pro
samedi 30 décembre 2017, 07:56
MY computer
CPU: i7 7770k
VGA:MSI 1080Ti
Display: LG 27UD69-W
AQ:AQ6pro D5pump Flow .....
SSD: 960EVO 500GB
:rolleyes:
Ce message a été modifié 1 fois. Dernière modification effectuée par "huanghetv" (30 décembre 2017, 07:57)
samedi 30 décembre 2017, 17:18
Very nice.
I have three questions:
1. is DIFF_Btm & DIFF_Top the temperature difference between the radiator out temps and the ambient room temp?
2. the pump speed seems fairly consistent (2715 to 2835 rpm) but the flow has a very wide range (135 to 279 l/h). What's up with that?
3. it looks like you have push/pull on your rad fans, but one side of both rads is running zero rpm. Is that not counter productive?
huanghetv
dimanche 31 décembre 2017, 00:42
Very nice.
A:
1. DIFF_Btm & DIFF_Top the temperature difference between the radiator inside water temps and the ambient room temp.
2.I dont know the reason,when I update aquasuite 2017.3.2,this often happens.
3.when DIFF_XX Temp bellow 8℃ ,onside is running zero rpm.
thx.
Ce message a été modifié 3 fois. Dernière modification effectuée par "huanghetv" (31 décembre 2017, 10:01)
Discussions similaires
