• 08.10.2026, 10:47
Undermoose
Aquaero 6 XT & Splitty9 - just got both and reading manual - hmm
samedi 13 janvier 2018, 16:42
Good thing I read manuals!
My first products, Aquaero 6 XT (plus heatsink) and Splitty9.
Aquaero fan header says max 2.5A.
Splitty9 says max 5a.
I had planned to use 11 Vardar fans (.35a peak) on the Splitty9, but it's looking like I could fry the Aquaero.
Is Splitty9 compatible? Do I need something else?
Thank you.
JL
Ce message a été modifié 1 fois. Dernière modification effectuée par "Undermoose" (13 janvier 2018, 16:43)
Undermoose
samedi 13 janvier 2018, 21:29
Thank you.
JL
There may be a way to put all the fans onto a Splitty9, but I think it's a bad idea from a control perspective.
I'm going to go with simple math, 5a max on Splitty9 can't go onto a single fan header on AQ6 with a 2.5a max. Maybe one of those power adjust modules would make it work, but 11 fans all operating at the same speed isn't the objective.
samedi 13 janvier 2018, 23:11
I think you answered your own question here. :)
Your second post in your other post on the subject is probably a good solution for you.
Undermoose
I've been known to do that!
dimanche 14 janvier 2018, 01:46
Yup!
:D
The two posts were headed toward the same answer! Just different topics.
