• 03.11.2026, 06:59
eCon1
D5 next sensor question
lundi 22 juillet 2019, 09:30
Hi everyone. Just install D5 Next in my rig. pump itself working fine but I got an issue with water temp sensor inside the pump.
When PC start LCD screen on D5 show water temp around 0c-2c and swing +/- 3c while system running.
I think that's not accurate even I correct temp offset in aquasuit that can plus 15c maximum.
Anyone facing the issue like this before? How can I fix?
Thanks in advance.
lundi 22 juillet 2019, 09:48
This is not normal, write a mail to the support: info@aqua-computer.de
eCon1
lundi 22 juillet 2019, 10:08
Thanks Sebastian. will write the email to support.
Discussions similaires
