• 05.10.2026, 05:07
SweetSnots
Farbwerk360 RGBpx pinout?
mercredi 11 août 2021, 20:22
I am using a bunch of Lian Li fans with this cable. According to Lian Li, if I use this cable (the argb one near the end), I can plug the fan RGB to my motherboard. I want to plug them to the Farbwerk 360 though. Is the pinout the same or do I need something else? Video of the cable I'm talking about.
Remayz
mercredi 11 août 2021, 20:46
the farbwerk360 has the same kind of ports. the pinout is identical to the one on motherboards.
SweetSnots
jeudi 12 août 2021, 01:18
Awesome, you saved my build, thank you so much!
Discussions similaires
