• 03.10.2026, 13:53
mbwdekeijzer
hard tubnning calibrate flow sensor.
jeudi 23 mars 2023, 00:42
Hello Aquaholics.
Bought a brand new ultitube 5 pro with leakshield.
I think this is a nice gadget.
Now i have a problem to calibrate my flow sensor, because i have hard tube i can not obstruct the loop so i have different things to do.
Tap the water off,
Change the acryl to add a valve
calibrate
take the valve out of the loop
But then is the flow different because there is no valve obstruction anymore.
So what is my best option to do.
thank in advanche
jeudi 23 mars 2023, 11:30
The 'flow sensor' on the D5 pump is an indicator of flow more than a flow meter.
With the large investment you have, I would recommend adding a FLOW METER.
Discussions similaires
