• 02.10.2026, 10:24
Jexx
Suggestions for a X48 MoBo
jeudi 10 avril 2008, 13:40
I'm new here and have a request.
I ordered a new MSI X48 Platinum motherboard and I was wondering which kind of coolingparts I should take.
This since the mobo has a CPU, NorthBridge and 2 chipsets it seems... ( the pictures arn't that good... ).
The factory heattube has to go ofcourse ^^
thnx in advance :)
[ + ] Immortality is only for those who are fit for it. [+]
Jexx
Re: Suggestions for a X48 MoBo
mardi 15 avril 2008, 13:16
Anybody? :/
For the CPU & northbridge I have found my things, It's just the chipsets i'm worried about.
Are those 2 identical normal sized chipsets or something else...
Jexx
lundi 12 mai 2008, 14:49
I finaly got my lovely mobo MSI X48.
After 3 day's of browsing the shop and looking I have found only the following:
- CPU block : OK
- NorthBridge : OK
- Chipset : OK
So I miss:
Voltage regulators & the PCI-Expander.
The PCI-expander has a very small distance between the 2 attachpoints (~43mm) and needs to be arround 30mm x 30mm block. ( PIC )
As you can see on the pictures the voltage regulator is a whole different mather...
PIC
edit: links didn't work, they do now :)
