• 26.09.2026, 13:54
Eumel
Painkiller Konsolenbefehle
mardi 29 juin 2004, 01:46
Gibts da welche?
Re: Painkiller Konsolenbefehle
mardi 29 juin 2004, 01:50
CONSOLE COMMANDS:
Here is list of Painkiller console commands (additional console information
can be found online at painkillergame.com):
STANDARD COMMANDS:
showweapon <0/1> - disables/enables weapon rendering
benchmark c5l1 - starts benchmarking test
msensitivity <value> - sets mouse sensitivity
msmooth <0/1> - disables/enables mouse smoothing
fov <value> - sets camera's FOV
crosshair <value (1-32)> - changes crosshair
hudsize <value (0.1-3.0)> - sets HUD size
speedmeter <1/0> - shows speed meter
weaponspecular <1/0> - enables weapon specular
showfps <1/0> - enables FPS display
exit
quit
MULTIPLAYER COMMANDS:
Server (commands available on server and for voting):
map <map_name> - changes current map
timelimit <value> - sets time limit
fraglimit <value> - sets frag limit
kick <name> - kicks player from the server
bankick <name> - kicks and bans player from the server
maxplayers <value> - sets max number of players on server
maxspectators <value> - sets max number of spectators on server
powerupdrop <0/1> - disable/enable powerup dropping (after map change)
powerups <0/1> - disable/enable powerups
weaponsstay <0/1>
teamdamage <0/1>
allowbunnyhopping <0/1>
allowbrightskins <0/1>
allowforwardrj <0/1>
gamemode <ffa/tdm/pcf/tlb/voosh> - changes game mode on server
reloadmap
Client:
team <1/2> - changes player's team
spectator <0/1> - disable/enable spectator mode
ready - sets the player ready for match
notready - sets the player unready for match
break - callvote for stopping the match
callvote <command command_params> - starts voting - callvote maxplayers 2
vote <yes/no> - agree or not agree to callvote
demoplay <filename_to_play_from>
demorecord <filename_to_record_in>
demostop
name <new_name> - changes player name
kill - player commints suicide
camerainterpolation <0/1> - disables/enables camera interpolation
connect <ip[:port]>
MULTIPLAYER TWEAKING COMMANDS:
prediction <0/1> - disables/enables client prediction
pushlatency <value> - in miliseconds, can be negative, eg. -10
actionsendperiod <value> - value is the number of miliseconds you want to
pass between sending your action packets to server
netstats - shows info of what's going in the network over the last 5 secs.
netstats overall - shows info of what's going in the network from the start
of the connection
netstats help - shows help for the command
Ich gehe mal nich davon aus, dass du Cheats suchst denn die würdest du in Google sofort finden ;D
Eumel
mardi 29 juin 2004, 01:55
Im Endeffekt such ich, wie man Bots hinzufügen kann im Multiplayer *fg*
