• 08.10.2026, 06:02
M3rl1N
call of duty 2 will nicht mehr ...
lundi 16 avril 2007, 22:40
Code source
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
<?xml version="1.0" encoding="utf-8" ?>
<ExceptionReport Version="4">
      <Application Build="25831" Command="&quot;G:\cod2\CoD2MP_s.exe&quot;       +connect 83.142.84.103:27910"/>
      <OperatingSystem Type="2"><Version Major="5" Minor="1" Build="2600"/></OperatingSystem>
      <Exception Code="C0000005" Address="0821ACA2"><Module Section="0001" Offset="00039CA2" FileName="G:\cod2\pb\pbcl.dll"/></Exception>
      <Registers EAX="279914B5" EBX="7C905FEC" ECX="00000001" EDX="7C98C0D8" ESI="7C906000" EDI="0824CF64" CS="001B" EIP="0821ACA2" SS="0023" ESP="0005DB90" EBP="0006F734" DS="0023" ES="0023" FS="003B" GS="0000" Flags="00210202"/>
      <BackTrace>
            <Frame ProgramCounter="0821ACA2" StackAddress="0005DB90" FrameAddress="0006F734">
                  <StackHexDump From="0005DB90" To="0005DC10">c8 d6 5d 00      10 00 00 00      00 00 00 00      00 00 00 00      00 00 00 65      00 00 00 00      00 00 00 00      00 00 00 65      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 6e      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00      00 00 00 00</StackHexDump>
            </Frame>
            <Frame ProgramCounter="0822FB07" StackAddress="0005DB90" FrameAddress="0006FE98">
                  <Module Section="0001" Offset="0004EB07" FileName="G:\cod2\pb\pbcl.dll"/>
                  <StackHexDump From="0006F734" To="0006F7B4">98 fe 06 00      07 fb 22 08      c8 d6 5d 00      5b 4e af 76      00 00 00 00      00 00 40 00      d2 39 08 00      00 00 00 00      9c 06 02 00      00 00 00 00      00 00 00 00      f4 01 00 00      00 00 00 00      00 00 00 00      34 00 00 c0      3d 04 92 7c      00 00 00 00      45 09 92 7c      4e 09 92 7c      00 00 00 00      00 00 00 00      00 90 fd 7f      34 00 00 c0      84 f7 06 00      00 90 fd 7f      05 10 91 7c      00 00 00 00      00 00 01 00      00 90 fd 7f      98 01 00 00      0e 44 92 7c      70 09 92 7c</StackHexDump>
            </Frame>
            <Frame ProgramCounter="0057DCD8" StackAddress="0005DB90" FrameAddress="0006FFC0">
                  <Module Section="0001" Offset="0017CCD8" FileName="G:\cod2\CoD2MP_s.exe"/>
                  <StackHexDump From="0006FE98" To="0006FF18">c0 ff 06 00      d8 dc 57 00      00 00 40 00      00 00 00 00      6d 23 08 00      0a 00 00 00      94 00 00 00      05 00 00 00      01 00 00 00      28 0a 00 00      02 00 00 00      53 65 72 76      69 63 65 20      50 61 63 6b      20 32 00 e4      00 f0 4d e4      00 00 4e e4      00 10 4e e4      00 20 4e e4      00 30 4e e4      00 40 4e e4      00 50 4e e4      00 60 4e e4      c5 a8 53 80      00 00 00 00      1c ec 9b b1      80 22 5b 8a      00 03 00 00      00 00 00 00      01 00 00 00      61 cc 04 00      10 00 00 00</StackHexDump>
            </Frame>
            <Frame ProgramCounter="7C816FD7" StackAddress="0005DB90" FrameAddress="0006FFF0">
                  <Module Section="0001" Offset="00015FD7" FileName="C:\WINDOWS\system32\kernel32.dll"/>
                  <StackHexDump From="0006FFC0" To="0006FFF0">f0 ff 06 00      d7 6f 81 7c      14 00 00 00      22 06 02 00      00 90 fd 7f      ed a6 54 80      c8 ff 06 00      20 90 e9 88      ff ff ff ff      a8 9a 83 7c      e0 6f 81 7c      00 00 00 00</StackHexDump>
            </Frame>
      </BackTrace>
</ExceptionReport>
das ist die fehler meldung laut xfire ...
was kann das sein?
@re@50
Re: call of duty 2 will nicht mehr ...
lundi 16 avril 2007, 22:42
wird irgendwas mit punkbuster sein.
M3rl1N
lundi 16 avril 2007, 23:07
hmm pc update is komplett neu und hat auch ge"updatet" aber des game crashed jetzt blos zum desktop zurück ...
habs grad erst neu installiert und gepatched ubd pc update gemacht aber irgendwie will es nciht andere games wie z.B.: Day of defeat source laufen einwandfrei...
@re@50
lundi 16 avril 2007, 23:08
DoD:Source nutz kein Punkbuster.
M3rl1N
lundi 16 avril 2007, 23:10
ja schon klar aber es nutzt VAC...
menst du das game crashed lustig zum desktop nur wegen PB?
verbuggte PBversion?
hmm morgen nochmal updatn und dann testen schade...
danke
