• 30.11.2026, 22:51
nicky_82
Strange Why Aqua Computer do not have poweradjust Black Frontplate or does anybody know where i can get my hands on two
jeudi 5 mars 2009, 15:37
Why Aqua Computer DO Not Have poweradjust Black Frontplate would it not be logich some of us do have black case and not silver ?(
why i'm asking because now i have 2 poweradjust silver 1 aquaero 4.00 USB Fan-Controller, black/white with black plate and also 1 aquatube G1/4 Delrin black without fittings and aquabay AT (installation bay for aquatube) Rev. 1.5, 1 Frontplate for aquabay AT aluminum black
my set not going to look right for sure
Ce message a été modifié 3 fois. Dernière modification effectuée par "nicky_82" (5 mars 2009, 21:53)
Swing Swing :P
Top_Nurse
jeudi 5 mars 2009, 20:17
Maybe they sell mostly LT versions? If you can find a black old style Aquastream plate it will probably fit.
nicky_82
jeudi 5 mars 2009, 20:23
all i can find is a old picture with all the black front plates
http://www.aqua-computer.de/prodimg/nd_p…editiom_500.jpg
Swing Swing :P
Top_Nurse
jeudi 5 mars 2009, 20:31
Let me look around in my junk pile and I will get back to you later.
nicky_82
jeudi 5 mars 2009, 20:33
thank you means alot
Swing Swing :P
drbo
jeudi 5 mars 2009, 22:29
But they have, they just dont show it
http://shop.aquacomputer.de/product_info…roducts_id=1952
this one fits perfectly (but the the black alu is a little bit thicker than the steel, so the screws isnt long enough) ...
I have two of theese in my rig ... http://www.diskusjon.no/index.php?act=at…=post&id=271105
As you can see from the pictures the screws look a litle bit strange, otherwise fine
Good luck
drbo
Ce message a été modifié 1 fois. Dernière modification effectuée par "drbo" (5 mars 2009, 22:33)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
nicky_82
vendredi 6 mars 2009, 00:33
yea just a shame they dont ship to thailand so i will have to ask gary from sidewinder to order it
Ce message a été modifié 4 fois. Dernière modification effectuée par "nicky_82" (6 mars 2009, 02:18)
Swing Swing :P
hobbes_dmS
vendredi 6 mars 2009, 07:10
ask at aqua-computer-berlin, they ship all around the world
drbo
vendredi 6 mars 2009, 07:41
They ship everywhere ... if you cant find your country in the webshop, just email them: info@aquacomputer.de
I did this a lot before the new webshop.
Good luck
nicky_82
vendredi 6 mars 2009, 13:06
well i did try and it said we can not ship to thailand
Swing Swing :P
Demodred
vendredi 27 mars 2009, 22:44
I sort of have the same problem.
I have all black cabinet, and all black faceplates for my aqua-computer stuff (aquaro and aquabay).
I recently ordred the Aquastream USB and a black faceplate, which was listed as on stock in the spare parts section at the time when I placed the order.
I did however not receive the black faceplate, and only got the information that they don't manufacture them anymore! Didn't give me time to make feedback on this, but just shipped the order.
And no, it will never look good having it painted or similar due to the writing done on it.
I'm just sad, as the only solution seems to be to hide the Aquastream inside my desktop case, but that will also hide the 2 light indicators, which is a shame:/
I should at least have had time cancelling, as I could have saved the money on the mounting parts and just went with the lt model.
As a side note, this Aquastream thingie is close to useless as it doesn't feature automatic control of my pump, like I can do with the fans via my Aquaro unit, so very disappointed here.
MrToad
samedi 28 mars 2009, 00:02
It might not be ideal, but what I've done with the Aquaero (which does have black faceplate, but as a good OCD sufferer, the difference between the shiny powdercoat finish of my case and the anodized finish of the faceplate was driving me down the road of insanity) is etch the finish of the original faceplate, apply self etching primer, paint with high-gloss automotive black, then use white transferable letters.
Tomorrow I might try to apply varnish, and see if it "eats" the transferable letters. If it doesn't they will last forever.
Of course, you won't get the Aquacomputer logo though. Unless you are/you know someone that is reaaaally good with the aerograph :D
Discussions similaires
