• 12.11.2026, 16:33
MUFFDIVER
Back again question as always :)
mardi 24 avril 2007, 13:58
So im back on the scene with water cooling and making my new shopping list as i see that i can now use my credit card to purchase your wonderful products again ;)
One shoggy how you been + like the new video mate very good.
Two :-
I have the M2N32 Sli Deluxe MB
And was wondering which Voltage regulator to use as both are listed and dont want to order the wrong one :/
Also i am useing SLI 2 x 7950 GT's and was wondering which chipset cooler to take for this MB.
+ i will be starting my new project which i will begin next month hopefully.
Any help on this would be brilliant.
Thanks
Muff.
b0nez
Re: Back again question as always :)
mardi 24 avril 2007, 15:12
Welcome back ;D
The Questions with the Voltage Regulators is an easy one. This cooler will fit on the board. And of course you need a pair of them.
The Chipsatzquestition isn't so easy to awnser. But I think I have the Awnser ;D
A normal Twinplex Pro should fit on the NB. And perhaps it fits also on the SB.
greetings and looking foreward to your new Project
b0nez
:rolleyes:
MUFFDIVER
mardi 24 avril 2007, 16:43
Are you sure about the Voltage regulators as im looking at it atm and it seems longer :-/ but i may be wrong. + if they are the wrong ones can i send them back as long as they are undamaged/unused.
MUFFDIVER
mardi 24 avril 2007, 16:53
Ok just read the spec sheet and i feel like a muppet. Ignore my last question. But anyone one the chipset coolers? Or anyone know or best educated guess.
TBH im with b0nez and think they shud be ok but i guess im just being cautious.
Muff.
