....seriously can i downgrade the firmware i much preferred the behaviour where from the moment it started it followed my settings.
Perform a clean install of AquaSuite.
Reset your device to facory defaults.
If the problem persists, please start a new thread on the forum detailing the specific issue, including screenshots and a description of the error.
This is not a fault with Aqausuite.
yea i'm doing most of my pointing toward the octo with the new firmware that i had to install because aquasuite demanded it but fine i'll play along maybe it's not pushing the profile correctly or whatever on to a aquasuite re-install and the 3rd damn factory reset of the octo since i was forced to update the firmware.
begrudgingly i must admit you were right clean install of aquasuite > factory reset > manually inputting settings to make sure so i don't re-bork it by importing a profile and it now works as intended again.
edit, never mind as i kinda expected it did nothing because the octo got borked because
Nothing you’ve described has been changed.
Reset the device to its factory settings using Aquasuite and reconfigure it.
according to the notes by the firmware the curve controller startup the thing i am having issue's with is litterally the only thing mentioned that got changed, so if i seem nettled it's because i am because most of my messages don't seem to be read correctly.
now i have re-instralled aquasuite, i have 3 times factory reset the damn thing, next up support for a octo with a older firmware and letting my licence expire when it all works so hopefully a update won't bork it again?
