 31.10.2025, 00:55
31.10.2025, 00:55 Sprache ändern
 Sprache ändern
						 Registrieren
 Registrieren Anmelden
 Anmelden
											Sie sind nicht angemeldet.
Zitat von »DerMaddin«
also ich hab jetzt mandrake 10 drauf. hab mir mal die install durchgelesen ...... und gemerkt, dass ich n richitger linux noob bin
da stand irgendwas von kernel einbinden oder von ordnern, wo ich gar net kenn. ....
geht das auch vom KDE aus ?
edit: ich habs von diesen w-lan treibern
For 2.6:
1. Latest module-init-tools. Ok, you probably don't need the very latest, but I don't want to guess what the minimum version should be, so just make sure you have the latest.
2. Latest gcc 3.x or 2.95.x. Chances are, many many other versions also work - I'm just not supporting them.
3. 2.6.9 kernel or newer. You must have your kernel tree installed and configured for kbuild to build your module. Crypto API (CONFIG_CRYPTO) and the ARC4 cipher must be compiled in or as modules or the driver will not work.
4. Wireless tools. Latest is prefered, but having slightly older versions are very unlikely to cause problems, at least compared to potential problems with the driver itself.
5. Latest hotplug scripts. This is somewhat optional, but it makes things easier.
To install, just run make install. You can also do make, then make modules_install, which uses the kernel build system to install the modules. However, if you do it the second way, you'll need to run depmod -a manually.
