Vous n’êtes pas connecté.
boo+
boo+
Citation de "back_orifice"
im notfall nen google link benutzen, und da in das feld einfügen lassen:
*suchwort* site:*deineseite.de*
wäre doch auch mal nen versuch wert... ;D ;D
boo+
boo+
Citation de "boo+"
Hi back_orifice
hast du ein Code dar für ?
oder weißt du wo es ein gibt
Code source |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 |
<script language="JavaScript">
Find In Page Script-
By Mike Hall (MHall75819@aol.com)
var NS4 = (document.layers); // Which browser?
var IE4 = (document.all);
var win = window; // window to search.
var n = 0;
function findInPage(str) {
var txt, i, found;
if (str == "")
return false;
// Find next occurance of the given string on the page, wrap around to the
// start of the page if necessary.
if (NS4) {
// Look for match starting at the current point. If not found, rewind
// back to the first match.
if (!win.find(str))
while(win.find(str, false, true))
n++;
else
n++;
// If not found in either direction, give message.
if (n == 0)
alert("Nichts gefunden.");
if (IE4) {
txt = win.document.body.createTextRange();
// Find the nth match from the top of the page.
for (i = 0; i <= n && (found = txt.findText(str)) != false; i++) {
txt.moveStart("character", 1);
txt.moveEnd("textedit");
// If found, mark it and scroll it into view.
if (found) {
txt.moveStart("character", -1);
txt.findText(str);
txt.select();
txt.scrollIntoView();
n++;
// Otherwise, start over at the top of the page and find first match.
else {
if (n > 0) {
n = 0;
findInPage(str);
// Not found anywhere, give message.
else
return false;
</script>
<form name="search" onSubmit="return findInPage(this.string.value);">
<font size=3><input name="string" type="text" size=15 onChange="n = 0;"></font>
<input type="submit" value="Suchen">
</form>
boo+
boo+
boo+
crushcoder
boo+
Citation de "Y0Gi"
eine suche lässt sich über eine scriptsprache wie php/perl/python auf dem server realisieren. entsprechende suchwörter müsste man irgendwo ablegen oder das script die titel in den html-dateien erkennen lassen.
crushcoder
