 31.10.2025, 18:39
31.10.2025, 18:39 Changer la langue
 Changer la langue
						 S’inscrire
 S’inscrire Connexion
 Connexion
											Vous n’êtes pas connecté.
																														 boo+
																		boo+
																														 boo+
																		boo+
Citation de "back_orifice"
im notfall nen google link benutzen, und da in das feld einfügen lassen:
*suchwort* site:*deineseite.de*
wäre doch auch mal nen versuch wert... ;D ;D
																														 boo+
																		boo+
																														 boo+
																		boo+
Citation de "boo+"
Hi back_orifice
hast du ein Code dar für ?
oder weißt du wo es ein gibt
|   | Code source |
| 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 | <script language="JavaScript">
Find In Page Script-
By Mike Hall (MHall75819@aol.com)
var NS4 = (document.layers);    // Which browser?
var IE4 = (document.all);
var win = window;    // window to search.
var n   = 0;
function findInPage(str) {
  var txt, i, found;
  if (str == "")
    return false;
  // Find next occurance of the given string on the page, wrap around to the
  // start of the page if necessary.
  if (NS4) {
    // Look for match starting at the current point. If not found, rewind
    // back to the first match.
    if (!win.find(str))
      while(win.find(str, false, true))
        n++;
    else
      n++;
    // If not found in either direction, give message.
    if (n == 0)
      alert("Nichts gefunden.");
  if (IE4) {
    txt = win.document.body.createTextRange();
    // Find the nth match from the top of the page.
    for (i = 0; i <= n && (found = txt.findText(str)) != false; i++) {
      txt.moveStart("character", 1);
      txt.moveEnd("textedit");
    // If found, mark it and scroll it into view.
    if (found) {
      txt.moveStart("character", -1);
      txt.findText(str);
      txt.select();
      txt.scrollIntoView();
      n++;
    // Otherwise, start over at the top of the page and find first match.
    else {
      if (n > 0) {
        n = 0;
        findInPage(str);
      // Not found anywhere, give message.
      else
  return false;
</script>
<form name="search" onSubmit="return findInPage(this.string.value);">
<font size=3><input name="string" type="text" size=15 onChange="n = 0;"></font>
<input type="submit" value="Suchen">
</form> |
																														 boo+
																		boo+
																														 boo+
																		boo+
																														 boo+
																		boo+
																														 crushcoder
																		crushcoder
																														 boo+
																		boo+
Citation de "Y0Gi"
eine suche lässt sich über eine scriptsprache wie php/perl/python auf dem server realisieren. entsprechende suchwörter müsste man irgendwo ablegen oder das script die titel in den html-dateien erkennen lassen.
																														 crushcoder
																		crushcoder
