You are not logged in.
Source code |
1 |
Avatar (Max 100x100): <input type="file" name="pic" /> |
Source code |
1 2 3 4 5 |
$pic = $_FILES['pic']; blabla $sql = "INSERT INTO user VALUES (null, '$username', '$password', '$mail', '$age', '$pic'" |
Source code |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 |
switch ($_GET['orderby'])
case "name":
$sql = "SELECT highscore.username, highscore.money, highscore.date, highscore.version, user.pic
FROM highscore WHERE money!=0
ORDER BY username ASC, money DESC";
$cnt2=500;
break;
blabla}
dbconnect();
$res = mysql_query($sql)
or dietrace(mysql_error());
if(mysql_num_rows($res))
$cnt =1;
while($cin = mysql_fetch_array($res))
if ($cnt<=$cnt2)
<tr>
<td>
<?php echo $cnt . "."; ?>
</td>
<td>
<?php echo $cin['username']; ?>
</td>
<td>
<?php echo $cin['money']; ?>
</td>
<td>
<?php echo $cin['date']; ?>
</td>
<td>
<?php echo $cin['version']; ?>
</td>
<td>
<?php echo '<img="'$cin['pic']'">s'; ?>
</td>
</tr>
<?php
$cnt++;
Source code |
1 |
move_uploaded_file($_FILES['pic']['tmp_name'], "pics/".$_SESSION["USER_ID"].".jpg") |
Source code |
1 |
echo "<img=\"/pics/".$cin['id'].".jpg\">"; |
Source code |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 |
<?php
session_start();
require_once('common.php');
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "[url]http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">[/url]
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1" />
<title>Change Details</title>
</head>
<body>
<?php
if(file_exists("pics/".$_SESSION['username'].".jpg"){
echo "File already exists";
else{
move_uploaded_file($_FILES['pic']['tmp_name'], "pics/".$_SESSION['username'].".jpg");
echo "Picture uploaded";
Here you can add an Image/Avatar to your account:
<form method="post" action="change.php" />
<table border="0" cellpadding="0" cellspacing="4">
<tr>
<td align="right">Avatar: </td>
<td><input type="file" name="pic" /></td>
</tr>
<tr>
<td><td align="right"><input type="submit" value="Register" /></td></td>
</tr>
</form>
</body>
</html>
Source code |
1 |
$filename = sprintf('user%04d.jpg', $user_id);
Source code |
1 2 |
upload_picture($_FILES['file'], $filename); delete_picture($filename); |
Quoted from "Wudel"
Hmm nunja, jetzt hab ich hier die change.php zurechtgepfuscht. Und mein Apache von XAMPP will nicht laufen, sodass ichs mal testen kann, schoise!
Dann den Apachen starten und du kannst auch wieder Skype anmachen. Skype klaut sich alles an Ports was es kriegen kann. Sehr ekelig. |
Source code |
1 |
echo "<img=\"/pics/".$cin['username'].".jpg\">"; |
Quoted from "Wudel"
ich wollte die bilder auch nicht nach dem schema 0000xxx.jpg speichern, sondern username.jpg
Quoted from "Wudel"
aber unabhängig davon, wird ein definitiv vorhandenes bild in dem verzeichnis mit der zeile code nicht angezeigt. hmm mal weitersuchen.
Source code |
1 |
<?php echo "<img src=\"pics/".$cin['username'].".jpg\">"; ?> |
