Du bist nicht angemeldet.
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 |
tobias@tobias-kanotix32:~$ cd aeinfo-2.2-src
tobias@tobias-kanotix32:~/aeinfo-2.2-src$ make
cat htdocs/fan.1.htm | sed -e "s/FAN 1/FAN 2/" -e "s/fan.1/fan.2/g" > htdocs/fan.2.htm
cat htdocs/fan.1.htm | sed -e "s/FAN 1/FAN 3/" -e "s/fan.1/fan.3/g" > htdocs/fan.3.htm
cat htdocs/fan.1.htm | sed -e "s/FAN 1/FAN 4/" -e "s/fan.1/fan.4/g" > htdocs/fan.4.htm
cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 2/" -e "s/sensor.1/sensor.2/g" > htdocs/sensor.2.htm
cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 3/" -e "s/sensor.1/sensor.3/g" > htdocs/sensor.3.htm
cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 4/" -e "s/sensor.1/sensor.4/g" > htdocs/sensor.4.htm
cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 5/" -e "s/sensor.1/sensor.5/g" > htdocs/sensor.5.htm
cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 6/" -e "s/sensor.1/sensor.6/g" > htdocs/sensor.6.htm
g++ -Wno-deprecated -DUSE_COLORS -Wall -lusb global.cpp -o aeinfo
In file included from comm.h:24,
from global.cpp:60:
usbio.h:33:18: error: usb.h: Datei oder Verzeichnis nicht gefunden
definePropMap.h: In function ‘void definePropertyMap(AquaeroData_rev4&)’:
definePropMap.h:165: warning: large integer implicitly truncated to unsigned type
definePropMap.h:166: warning: large integer implicitly truncated to unsigned type
definePropMap.h:167: warning: large integer implicitly truncated to unsigned type
definePropMap.h:168: warning: large integer implicitly truncated to unsigned type
definePropMap.h:169: warning: large integer implicitly truncated to unsigned type
definePropMap.h:170: warning: large integer implicitly truncated to unsigned type
comm.h: At global scope:
comm.h:14: warning: ‘class AquaeroCommunication’ has virtual functions but non-virtual destructor
usbio.h:128: error: ISO C++ forbids declaration of ‘usb_dev_handle’ with no type
usbio.h:128: error: expected ‘;’ before ‘*’ token
usbio.h:249: error: ‘usb_dev_handle’ has not been declared
usbio.h:433: error: ISO C++ forbids declaration of ‘usb_dev_handle’ with no type
usbio.h:433: error: expected ‘;’ before ‘*’ token
usbio.h:549: error: expected `;' before ‘string’
usbio.h: In member function ‘void USBCommunication::close_device()’:
usbio.h:181: error: ‘open_handle’ was not declared in this scope
usbio.h:181: error: ‘usb_close’ was not declared in this scope
usbio.h: In member function ‘usb_device* USBCommunication::init_device()’:
usbio.h:272: error: ‘usb_init’ was not declared in this scope
usbio.h:273: error: ‘usb_find_busses’ was not declared in this scope
usbio.h:274: error: ‘usb_find_devices’ was not declared in this scope
usbio.h:276: error: ‘usb_get_busses’ was not declared in this scope
usbio.h:276: error: invalid use of undefined type ‘struct usb_bus’
usbio.h:269: error: forward declaration of ‘struct usb_bus’
usbio.h:278: error: invalid use of undefined type ‘struct usb_bus’
usbio.h:278: error: invalid use of undefined type ‘struct usb_device’
usbio.h:266: error: forward declaration of ‘struct usb_device’
usbio.h:280: error: invalid use of undefined type ‘struct usb_device’
usbio.h:281: error: invalid use of undefined type ‘struct usb_device’
usbio.h: In member function ‘std::string USBCommunication::readAEString()’:
usbio.h:551: error: ‘usb_dev_handle’ was not declared in this scope
usbio.h:551: error: ‘aq’ was not declared in this scope
usbio.h:551: error: ‘get_aquaero_handle’ was not declared in this scope
usbio.h:562: error: ‘usb_interrupt_read’ was not declared in this scope
usbio.h:598: error: ‘usb_close’ was not declared in this scope
usbio.h: In member function ‘void USBCommunication::writeAEString(std::string)’:
usbio.h:621: error: ‘usb_dev_handle’ was not declared in this scope
usbio.h:621: error: ‘aq’ was not declared in this scope
usbio.h:621: error: ‘get_aquaero_handle’ was not declared in this scope
usbio.h:640: error: ‘usb_control_msg’ was not declared in this scope
usbio.h:696: error: ‘usb_close’ was not declared in this scope
ipc.h: At global scope:
ipc.h:1080: warning: ‘class AquaeroDaemonService’ has virtual functions but non-virtual destructor
global.cpp: In function ‘int main(int, char**)’:
global.cpp:380: warning: unused variable ‘ret’
make: *** [all] Fehler 1
Auf Deinem System ist die libusb nicht installiert. Für die Kompilierung wird unter Umständen auch ein libusb-devel-Paket benötigt...
Quellcode
1 usbio.h:33:18: error: usb.h: Datei oder Verzeichnis nicht gefunden
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 |
root@tobias-kanotix-vmware:/home/tobias/Desktop/aeinfo-2.2-src# make cat htdocs/fan.1.htm | sed -e "s/FAN 1/FAN 2/" -e "s/fan.1/fan.2/g" > htdocs/fan.2.htm cat htdocs/fan.1.htm | sed -e "s/FAN 1/FAN 3/" -e "s/fan.1/fan.3/g" > htdocs/fan.3.htm cat htdocs/fan.1.htm | sed -e "s/FAN 1/FAN 4/" -e "s/fan.1/fan.4/g" > htdocs/fan.4.htm cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 2/" -e "s/sensor.1/sensor.2/g" > htdocs/sensor.2.htm cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 3/" -e "s/sensor.1/sensor.3/g" > htdocs/sensor.3.htm cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 4/" -e "s/sensor.1/sensor.4/g" > htdocs/sensor.4.htm cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 5/" -e "s/sensor.1/sensor.5/g" > htdocs/sensor.5.htm cat htdocs/sensor.1.htm | sed -e "s/SENSOR 1/SENSOR 6/" -e "s/sensor.1/sensor.6/g" > htdocs/sensor.6.htm g++ -Wno-deprecated -DUSE_COLORS -Wall -lusb global.cpp -o aeinfo definePropMap.h: In function ‘void definePropertyMap(AquaeroData_rev4&)’: definePropMap.h:165: warning: large integer implicitly truncated to unsigned type definePropMap.h:166: warning: large integer implicitly truncated to unsigned type definePropMap.h:167: warning: large integer implicitly truncated to unsigned type definePropMap.h:168: warning: large integer implicitly truncated to unsigned type definePropMap.h:169: warning: large integer implicitly truncated to unsigned type definePropMap.h:170: warning: large integer implicitly truncated to unsigned type comm.h: At global scope: comm.h:14: warning: ‘class AquaeroCommunication’ has virtual functions but non-virtual destructor ipc.h:1080: warning: ‘class AquaeroDaemonService’ has virtual functions but non-virtual destructor global.cpp: In function ‘int main(int, char**)’: global.cpp:380: warning: unused variable ‘ret’ g++ -Wno-deprecated -Wall -lusb -lpthread aquaerod.cpp -o aquaerod definePropMap.h: In function ‘void definePropertyMap(AquaeroData_rev4&)’: definePropMap.h:165: warning: large integer implicitly truncated to unsigned type definePropMap.h:166: warning: large integer implicitly truncated to unsigned type definePropMap.h:167: warning: large integer implicitly truncated to unsigned type definePropMap.h:168: warning: large integer implicitly truncated to unsigned type definePropMap.h:169: warning: large integer implicitly truncated to unsigned type definePropMap.h:170: warning: large integer implicitly truncated to unsigned type comm.h: At global scope: comm.h:14: warning: ‘class AquaeroCommunication’ has virtual functions but non-virtual destructor ipc.h:1080: warning: ‘class AquaeroDaemonService’ has virtual functions but non-virtual destructor aehttpd.cpp: In member function ‘std::string ScriptParser::executeScript(std::string, std::string)’: aehttpd.cpp:713: warning: comparison between signed and unsigned integer expressions aehttpd.cpp:747: warning: comparison between signed and unsigned integer expressions aehttpd.cpp:813: warning: comparison between signed and unsigned integer expressions aehttpd.cpp: In member function ‘bool HttpResponse::checkURI(std::string)’: aehttpd.cpp:1248: warning: comparison between signed and unsigned integer expressions lex.yy.c: At global scope: lex.yy.c:1008: warning: ‘void yyunput(int, char*)’ defined but not used |
