Sie sind nicht angemeldet.
(...) Auch das Firmware-Update für Platten der Reihe Barracuda ES.2, die unabhängig von ihrem gegenwärtigen Firmware-Stand vom Bug betroffen scheinen, trägt derzeit noch den Status "In Validation" und wird erst später erscheinen. (...)
tr3c00l
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »tr3c00l« (19. Januar 2009, 23:16)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »fksystems« (21. Januar 2009, 15:45)
tr3c00l
Soll ich DAS jetzt installieren?
Thank you for contacting Seagate Support.
A firmware issue has been identified that affects a small number of
Seagate Barracuda 7200.11 hard drive models which may result in data
becoming inaccessible after a power-off/on operation. The affected
products are Barracuda 7200.11, Barracuda ES.2 SATA, and DiamondMax 22.
Based on the low risk as determined by an analysis of actual field return
data, Seagate believes that the affected drives can be used as is.
However, as part of our commitment to customer satisfaction, Seagate is
offering a free firmware upgrade.
Please follow this link
(http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=207931)
to enter the Knowledge Base article(s) detailing the steps to update your
drive.
In the unlikely event your drive is affected and you cannot access your
data, the data still resides on the drive and there is no data loss
associated with this issue. If your drive is no longer accessible, contact
us directly for further assistance at
http://www.seagate.com/www/en-us/about/contact_us/.
NOTE: If you have contacted Seagate Support regarding a separate issue or
about another product, please visit
http://www.seagate.com/www/en-us/about/contact_us/ to submit an email.
Thank you.
Seagate Support
