Sie sind nicht angemeldet.
Yeah I'm also very interested in this, since I may have to split up my loop that I was planning to do and therefore adding one more Aquastream. But if it is the AS XT Ultra more of the devices is combined in one, so is it then possible or is it more or less the same question as stated above?I also have a question regarding complex watercooling setups (involving multiple separate cooling loops) :
Let's suppose that I am planning a complex watercooling setup with more than 1 (separate) cooling loop. Each loop has its own AquaStream pump, reservoir, TubeMeter, flow meter, radiators, and so on...
Is it possible to properly control this complex setup with 1 Aquaero ? Can the Aquaero handle this without problems if I would make my own AquaBus Y-splitter cable that has more than 2 connectors and allows me to connect all my devices to it ? Can the Aquaero actually distinguish all the devices properly ?
How would I set up such a complex watercooling and control setup ?
The aquasuite software will bring up a new tab for every device that is connected.The aquabus is already limited by the fact that there are only five devices that you cold hook up to the aquaero:
2 x aquastream
2 x multiswitch
1 x tubemeter
The 127 that you might have read somewhere is the limit of one USB port. You can connect a few hundred Aqua Computer devices to a single PC if you are mad enoughThe aquasuite software will bring up a new tab for every device that is connected.
Greetings >Evil E.<I have found some contradictory information here on the forum regarding certain details about your products (example : 1 post mentions that AquaBus can handle 127 devices, but another post mentions AquaBus can
handle 64 - use the Search-function of the forum, then you can see for yourself what I mean). As you will agree with me, this doesn't help users at all, it only makes it more confusing for everybody.![]()
So I would like to suggest that the AC staff post 1 or more sticky threads that has all the correct and relevant information regarding certain details (Aquaero, AquaStream, AquaSuite, AquaBus, TubeMeter, etc. ...). Having all the necessary information in 1 relevant thread will help avoid confusion, and it will help all people to find answers to certain questions.
