Sie sind nicht angemeldet.
WebMaximus
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »WebMaximus« (15. Februar 2009, 01:50)
WebMaximus
) so I'm really looking forward stop typing here now and get on with the installation
Must honestly say though I'm very surprised there isn't a printed english hardware and installation documentation included in a quality product like this one and in this price-range. If there isn't one available I guess I'll have to try OCR scan the German documentation and then find some online service or such that can translate to English...doesn't feel a bit awkward...
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »WebMaximus« (15. Februar 2009, 14:18)
WebMaximus
2% is the required and maximum amount that should be used. Overdoing it creates all kinds of problems. To get rid of the air turn on the deaeration mode. You will find this in the pump section of the software.Managed to set the system up yesterday by guessing and with some help from Google Translate...however I have one question. I used distilled water and then added some of the ACfluid that came with the product but I might have added too much because now after running the system for about one day the water is almost white like milk and I also seem to have lots of air in the loop and not sure how to avoid that or how to get rid of it when it's already in there...?
Thanks in advance for any advice!
WebMaximus
? I've already said it but I say it again, I'm very surprised in a bad way you don't get an English hardware and installation guide with the system when you buy it so you can avoid all these kind of "mishaps" when you're not German. Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »WebMaximus« (17. Februar 2009, 00:31)
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Top_Nurse« (17. Februar 2009, 06:18)
WebMaximus
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »WebMaximus« (17. Februar 2009, 12:49)
