Sie sind nicht angemeldet.
MrToad
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Timstone« (19. April 2009, 11:33)
Holy, holy...![]()
Could someone please answer my questions in the way I posted them in the first place?
No harm intended from my side, it's just easier for me to read that way.
Hi all,
These are my questions:
- Which pump to chose?
- Which diameter tubes to chose?
- How many temperature sensors, where to place them and which kind to chose?
- Which kind of flow sensor to chose?
- Is the setup I chose correct?
- Did I forget somehting?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »fox3« (19. April 2009, 18:11)
Hi all,
It has been some thime since I posted here. But now I'm going to overhaul my system big time, I need some advise. Here it goes!
This is what I want:This is the setup I have in mind:
- PC-A77B case
- CPU cooler
- 2 GPU coolers
- Pump is automaticly regulated by the water temperature
Radiator --> CPU --> GPU I --> GPU II --> Temp. sensor --> Reservoir --> Pump --> Flow sensor -->
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »Top_Nurse« (20. April 2009, 10:12)
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »drbo« (24. April 2009, 00:15)
I have run several setups on my complete wc workstations, and years of experience has given me this rule of thumb regarding cooling power - in terms of how much radiator is needed (meassured in # of 120mm fans over radiator). This rule has hold nicely so far with both amd and intel cpus. The internal temp sensor of the aquastream I don't trust, since it always showed far to high temp compared to my other 4 sensors, and also the temp differense was not stable .
