 31.10.2025, 17:59
31.10.2025, 17:59 Sprache ändern
 Sprache ändern
						 Registrieren
 Registrieren Anmelden
 Anmelden
											Sie sind nicht angemeldet.
|   | Quellcode |
| 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 | /dev/md0:
        Version : 00.90
  Creation Time : Tue Sep  1 09:05:20 2009
     Raid Level : raid5
     Array Size : 1943511296 (1853.48 GiB 1990.16 GB)
  Used Dev Size : 971755648 (926.74 GiB 995.08 GB)
   Raid Devices : 3
  Total Devices : 3
Preferred Minor : 0
    Persistence : Superblock is persistent
    Update Time : Tue Sep  1 09:05:20 2009
          State : clean
 Active Devices : 3
Working Devices : 3
 Failed Devices : 0
  Spare Devices : 0
         Layout : left-symmetric
     Chunk Size : 64K
           UUID : fa566525:b879f9d9:a6207b33:a0e20965
         Events : 0.1
    Number   Major   Minor   RaidDevice State
       0       8       17        0      active sync   /dev/sdb1
       1       8       33        1      active sync   /dev/sdc1
       2       8       49        2      active sync   /dev/sdd1 |
|   | Quellcode |
| 1 2 3 4 5 6 | Personalities : [raid6] [raid5] [raid4]
md0 : active (auto-read-only) raid5 sdb1[0] sdd1[2] sdc1[1]
      1943511296 blocks level 5, 64k chunk, algorithm 2 [3/3] [UUU]
      	resync=PENDING
unused devices: <none> |
|   | Quellcode |
| 1 2 3 4 5 6 7 8 9 | # /etc/fstab: static file system information. # # <file system> <mount point> <type> <options> <dump> <pass> proc /proc proc defaults 0 0 /dev/sda1 / ext3 errors=remount-ro 0 1 /dev/sda5 none swap sw 0 0 /dev/hda /media/cdrom0 udf,iso9660 user,noauto 0 0 #manuell eingefügte Zeile; Raid5 /dev/md0 / ext3 defaults 0 0 |
|   | Quellcode |
| 1 2 | mkdir /mnt/RAID mount /mnt/md0 /mnt/RAID |
|   | Quellcode |
| 1 2 3 4 | mount: wrong fs type, bad option, bad superblock on /dev/md0,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so |
								|   | Quellcode |
| 1 | mount /dev/md0 /mnt/RAID |
|   | Quellcode |
| 1 2 3 4 5 6 7 8 9 | mdadm --stop /dev/md0 mdadm --zero-superblock /dev/sdb1 mdadm --zero-superblock /dev/sdc1 mdadm --zero-superblock /dev/sdd1 mdadm --create /dev/md0 -c 128 -l 5 -n 3 /dev/sdb1 /dev/sdc1 /dev/sdd1 -x 0 -f -R aptitude install xfsprogs mkfs.xfs /dev/md0 mkdir /mnt/RAID mount /dev/md0 /mnt/RAID |
|   | Quellcode |
| 1 | /dev/md0 /mnt/RAID xfs defaults 0 0 |
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Labrat« (1. September 2009, 16:08)
|   | Quellcode |
| 1 2 3 4 5 | sonnengott:/home/dau# mount /dev/md0 /mnt/RAID
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Sonni« (1. September 2009, 16:16)
								|   | Quellcode |
| 1 2 3 4 5 6 | mdadm --create /dev/md0 -c 128 -l 5 -n 3 /dev/sdb1 /dev/sdc1 /dev/sdd1 -x 0 -f -R mdadm --detail --scan > /etc/mdadm.conf fdisk -l mkfs.ext3 /dev/md0 mkdir /mnt/RAID mount /dev/md0 /mnt/RAID |
								 Gut dass du mich erinnerst, ich werd die Tage wohl auch nochmal meinen Linux Server in Angriff nehmen, wenns dann nach dem x-ten mal nicht klappt MUSS es einfach der SATA Controller sein
 Gut dass du mich erinnerst, ich werd die Tage wohl auch nochmal meinen Linux Server in Angriff nehmen, wenns dann nach dem x-ten mal nicht klappt MUSS es einfach der SATA Controller sein  derweil handelt es sich bei mir um ein sehr einfaches Raid 0 oder JBOD ..
 derweil handelt es sich bei mir um ein sehr einfaches Raid 0 oder JBOD ..							|   | Quellcode |
| 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 | sonnengott:/home/dau# cat /proc/mdstat
md0 : active raid5 sdb1[0] sdd1[2] sdc1[1]
      1943511296 blocks level 5, 128k chunk, algorithm 2 [3/3] [UUU]
sonnengott:/home/dau# mdadm --detail --scan /dev/md0
mdadm: Unknown keyword EMAILADDR
/dev/md0:
        Version : 00.90
  Creation Time : Wed Sep  2 08:34:24 2009
     Raid Level : raid5
   Raid Devices : 3
  Total Devices : 3
Preferred Minor : 0
    Update Time : Wed Sep  2 18:20:37 2009
          State : clean
 Active Devices : 3
Working Devices : 3
 Failed Devices : 0
  Spare Devices : 0
     Chunk Size : 128K
           UUID : 487229c4:c2021c5d:c9cc1c39:cf08bea4
         Events : 0.8
|   | Quellcode |
| 1 2 | sonnengott:/home/dau# mkdir /mnt/test2 sonnengott:/home/dau# mount /dev/md0 /mnt/test2 |
|   | Quellcode |
| 1 2 | 04:00.0 RAID bus controller: Silicon Image, Inc. SiI 3114 [SATALink/SATARaid] Serial ATA Controller (rev 02) sonnengott:/home/dau# |
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Sonni« (2. September 2009, 18:32)
								Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »hurra« (3. September 2009, 11:16)
 server installiert man normal ohne grafische oberfläche. das ist einfach praktischer, weil du zum administrieren i.d.R. eh nur die shell verwendest (z.b. über putty).
deswegen kann dir hier auch keiner helfen, weil wir solche probleme nicht kennen.
 Hardware, allgemein »
 Hardware, allgemein » RAID 0 mit Vista Business
											(9. März 2009, 23:05)
										 Software, allgemein »
 Software, allgemein » Daemon Tools für Linux ?
											(20. September 2003, 06:35)
 Software, allgemein » mandrake linux newbie frage
											(26. Mai 2003, 18:50)
 Software, allgemein » suse 8.0 linux setup bricht installation ab...
											(9. September 2002, 04:17)
