Dont know if this is the right place for this,thought i would show you where i am with my next project Acrylin 343b.
Most of the case will have white acrylic
Motherboard and top panel cut
I did cut two more panels but i will be doing two new ones for the rear and front as im changing the rear grill and the front res to a Aquatube
I also attacked the rear with a new peice of alluminium
Done a bit this weekend not much, where i am at the mo
Front test fitting still got to cut out for the grills
Top test fit with grill and bolts
Side panel test fit,got to get a peice cut out for a peice of clear acrylic so it sits flush with the panel
Something like this from my old case a while ago but without the bits on the side
If all goes well this is what i hope the front will look like
This is what im using at the mo my firrst attempt at getting wet,plus i treated myself to a new desk ready for when ive done my next build.
Thanks for looking
Ian
