You are not logged in.
Maximillien
creekin
This post has been edited 1 times, last edit by "creekin" (Nov 30th 2010, 12:48am)
Maximillien
I have Win7(64bit) and it worked great until I connect an Aquastream on USB too. So I'm not sure it's win7 related.Did I read somewhere that it does not like Win-7 64 bit I am getting ready to wire and install mine soon
This post has been edited 1 times, last edit by "Maximillien" (Nov 30th 2010, 8:32am)
We do not provide any kind of driver nor have we programmed something like that. We just use the general HI-Device driver provided from the operating system. This thing is clearly based on given USB specifications where we can prove that the aquaero is 100% compatible to them. We also invested A LOT of time into these problems with some Asus mainboards. Long story short: this problem will never be solved. We are not willing to spend any more time on this since we already did that more than enough. Making 9995 users happy in 5 minutes and than 500 minutes more for the remaining 5? - That does not work and I'm sure you would do the same if you have to run a company.Guess what the solution is ? Yes Driver re-install.
Did it worked ? Yes
Do I still think that AquaComputer has nothing to do with this bug ? Unfortunately no.
Regards,
Maximillien, a proud customer of AquaComputer that feels the money he spent on this hardware should at least reflect in the translation of the AquaSuite program.
The manuals are translated into English. If your device did not come with one you can download it in our support area or request it by e-mail. I would also say we did a lot of in the past for the software. Do you know how everything started?Please translate your manuals properly, and invest some of the ridiculous amounts of money we pay (AUD$300 for a fan controller!!) for Aquaero back into aquasuite development....
PLEASE!!!
The aquasuite is fully compatible to all Windows 7 versions.Did I read somewhere that it does not like Win-7 64 bit I am getting ready to wire and install mine soon
Maximillien
Maximillien
I hope you the best, my internal usb hub is also the one from NZXT, let us (the comunity) know if you come into any problem.Max.
I have a EVGA board BUT!!! I am planning on a NXT USB board mounted in drive cage to handle my aquaero and 3 power Adjusts along with my LCD screen. So I hope I'm OK
