Thank you very much for the reply.
However is the flow measurement of the AC high flow sensor affected from the size of the tubes used in the loop? If the size of the tubes (inner diameter) affects the measuring ability of the sensor, then it means that the impulses per Liter must be changed to a different value than the reference value given by AC. This can be done by measuring in fact the litres flowed per minute into a bucket and doing the averaging of the results, and then changing the value of impulses per liter in the aquasuite. If you agree with my previous argument, then for which tubing size has AC measured and defined the impulses per liter in the high flow sensor manual?
In the Aquasuite the pump speed can be set either to automatic or manual. However when we select the automatic, which enviromental variable is used to control the pump speed? In other words, is it possible to change the operational speed of the Aquastream XT pump according to the internal to the pump or the external temperature sensor? in the similar way that the fan speed is proportional to the external temperature sensor. Is this possible with the aquastream XT and the aquasuite alone or it can be done with the aquaero?
Thanks for your support.
Aster1x
