Sie sind nicht angemeldet.
Scott Loves Dogs
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Scott Loves Dogs« (13. November 2012, 18:09)
BorisTheSpider
Thanks for the news.
This will be my first time updating, and I have quite a lot of setup done, so I'd like to understand exactly what will need reconfiguring.
Will my current overview page work?
When you say all settings need re-entering, does that mean literally everything - as in all sensors will go back to default names, virtual sensors will disappear etc?
BorisTheSpider
Scott Loves Dogs
Same here, just hangs and does nothing near the very end. Maybe a reset is needed?I installed the new version, but can't seem to update the firmware! it seems to be just hanging in the last bit.![]()
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Scott Loves Dogs« (14. November 2012, 04:59)
Phatboy69
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Phatboy69« (14. November 2012, 05:46)
I am Intel of Borg. Resistance is futile. You will be assimilated.This is the same as the normal xml export (same xml sheme). This file is available with the name from "aquasuite-export-.....".Shoggy can you please share more about how the Shared Memory logging feature is implemented?
Scott Loves Dogs
Thank you Sebastian, and everyone else, for the very fast update.We have updated the aquasuite 2012. Download and reinstall the aquasuite.
