Sie sind nicht angemeldet.
LossMentality
Freitag, 23. November 2012, 05:26
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »LossMentality« (26. November 2012, 22:28)
LossMentality
LossMentality
LossMentality
LossMentality
LossMentality
LossMentality
LossMentality
Also, not all of the aida64 temperature sensors showed up in aquasuite's software sensor datasource list, even though I had them all checked for export to WMI in aida64. This included two of the four CPU core temps and both of the GPU temps. I guess that doesn't matter though, since I'll probably stick with OHM since it's free and aida64 has the same issue.
LossMentality
Seems like something is interfering with the Aqua Computer process if it runs too early. I'll try the delay start service option and if that doesn't help I'll probably right a script that launches at boot but waits 30 seconds to start the service.... Or I've been meaning to reinstall Windows anyway, so this might be a good time to see if it helps. on mine...it even seems like Aida loads after Aquasuite. I have Aquasuite checked to run at start and minimize to task tray. It's always there way before Aida finishes its thing.Yes, I guess so.Seems like something is interfering with the Aqua Computer process if it runs too early. I'll try the delay start service option and if that doesn't help I'll probably right a script that launches at boot but waits 30 seconds to start the service.... Or I've been meaning to reinstall Windows anyway, so this might be a good time to see if it helps.
LossMentality
LossMentality
