Vous n’êtes pas connecté.
Balanar
Ce message a été modifié 1 fois. Dernière modification effectuée par "Balanar" (27 janvier 2013, 16:24)
Ce message a été modifié 2 fois. Dernière modification effectuée par "_KaszpiR_" (27 janvier 2013, 11:11)
cc01
1) I have wanted to use the Aquacomputer pumps to maximize compatibilty but I will be using the Bitspower D5 Pump Mod Kit and don't think the pumps will fit properly. They will probably lack space for the wires to plug in. Can anyone confirm this?
Ce message a été modifié 3 fois. Dernière modification effectuée par "cc01" (27 janvier 2013, 11:52)
Balanar
I sincerely thank you for your reply KaszpiR!1. No idea, but I wish someone could answer it, I'm also interested in the reply.
2. You have two ways of controlling the pumps - controlling the voltage or controling the PWM signal.
When controlling a voltage then you would have to connect the pump to the Aquaero, and if the pump has molex, then you will have to probably convert it to 3pin fan connector.
The down side is that when controlling pumps by voltage, then there is a lot of generated heat on the controller itself, and usually you can connect up to 1 pump to the designated fan header to avoid over-current and overheating.
When controlling over voltage then you usually just have to connect the PWM signal to the spare fan or the PWM outputs, in the second option I believe you would have to change to 2pin plug.
This is better solution, because you can steer both pumps from the same PWM signal (of course they will change speed both in the same way, you cannot control them independently from the single output)
You may be also interested in this - http://shop.aquacomputer.de/product_info…roducts_id=2901
I'm currently in the process of getting one of those - it allows to control and read data from each pump independenlty.
3. No, if you will use splitters for fans. You can run fans on all channels, and pumps on PWM signals. But then you will get confusing rpm signals if you join RPM reading signals (so the best is to read RPM from only one fan)
If you want to control and read RPM signal for each and every device like fan or pump, then yes - you will need Poweradjust, probably 2 - but then I think that's an overkill
In your setup I would use something like this:
aquaero fan1 -> splitter 3x fans on top
aquaero fan2 -> extender 30cm -> splitter 6x fans on second rad
aquaero fan3 -> splitter + estenders to other fans in the case, if any (front, back, bottom etc)
aquaero PWM 1 -> pump 1
aquaero PWM 2 -> pump 2
Optionally you could control vial PWM both pumps, so you would need a Y splitter.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Balanar" (27 janvier 2013, 16:56)
Balanar
cc01, thank you for your reply as well!1) I have wanted to use the Aquacomputer pumps to maximize compatibilty but I will be using the Bitspower D5 Pump Mod Kit and don't think the pumps will fit properly. They will probably lack space for the wires to plug in. Can anyone confirm this?
The Bitspower Pump Kit contains two peices: the cylindrical barrel which houses the pump and mounts it to the pump top and a flat disc that simply fits into the end of the barrel to seal it up and hide the end of the pump. With the disc inserted an AC pump would not be compatible with the Bitspower kit, however the disc is only cosmetic. I am using the same kits on my Aquacomputer D5 pumps and I just didn't insert the disc and there is no obstruction between between the pump kit and the connectors on the AC pump.
If you use a black Bitspower kit it might match with the black sticker on the end of the AC pump, although I have simply turned the connector side of the pumps away from sight to facilitate hidden wiring and used the colour of my choice. The AC D5 pumps are a good choice because you can plug them directly into the power supply (ie eliminate the need for a poweradjust or using an output on the aquaero to power the pump) and you can adjust them to a much lower speed than other D5 variants. They also seem to run a lot quieter than other D5s I've experienced and are nicely integrated with the Aquaero and Aquasuite, having more monitoring options and possibilities for alarm configuration![]()
cc01
Balanar
cc01
cc01
