(thanks for the move)
So I want to buy the Aquaero 5 LT and have it control a Swiftech Apogee drive 2 off the pwm header, 4 Swiftech Helix 140mm 3 pin in push/pull off my front radiator on 1 channel, 2 Swiftech Helix 120mm pwm in pull off my top radiator with the 2nd channel, and 2 Swiftech Helix 140mm 3 pin as case fans on the last channel.
My question is mainly about power for the fans in my front radiator. I understand that the maximum is 19.8 watts and 1.65 amps? So if I ran 4 Helix with voltage ~7 - 13.8 VDC and current 0.45 A it would be too much? If it is what do you recommend. Or can I just run the fans below maximum?
Also with the planned setup should I run a passive cooler such as:
Thank you!
ugggh looks like the limit on the PWM header is 1A so my 1.5A Apogee Drive 2 in too powerful.. Guess Ill run it off the motherboard header then and split the fans up off the other headers on the aquaero..
