You are not logged in.
NotHaPPy
NotHaPPy
Thanks for answer, i have it connected right also on mainboard, but still not recognized. Now after reboot it doesnt even say it is not recognized. Red light is on, but thats all. Doesnt matter if i connect output to pump, am finished with it. Time for RMAHi NotHaPPy,
Yup, the lack of the English manual is a pain.
I could have also used an installation/assembly manual for the front plate for the Poweradjusts, in the end I basically used photos from the online shop to figure out how many washers I need and where.
Anyway, check that your USB cable is connected properly. Pin 1 (red wire) on the Poweradjust USB connector is the one closest to the Aquabus connectors and the temperature sensor connection. Also, check the USB connection on your motherboard.
There is no driver for the Poweradjust, it is a standard USB device, Windows has all that it needs for it.
Disconnect the Aquabus connection if you have it connected, connect the Poweradjust only over USB and start Aquasuite 4.72, that is the one that you need to set it up.
Your pump is off, probably because the default state of the Poweradjust output is off (0).
Kind regards,
Boris.
marchitect
The reason for those standoffs is because everyone doesn't buy a bay mount for PA2's.Here's a video I did to assist with the assembly of the PA's
This may help some people out there. I know it wasn't obvious for me.
http://www.youtube.com/watch?v=zan4YymciIc
How else would you mount them to anything else without them? For example I have 3 PA2's and never even considered buying a bay mount because my bay area is maxed out already. This post has been edited 1 times, last edit by "Pilo" (Mar 13th 2013, 3:12pm)
lol.Two words: Common Sense!
12 standoffs...8 longer, 4 shorter ones...1 mounting bezel...12 holes...8 shorter (thin metal sheet)...4 longer ones (doubled metal sheets)...and you guys seriously complain about it how complicated it is to attach three PA2 to one mounting bezel? Are you kidding me? How do you guys find your bathrooms and beds? Only with GPS?
I mean, the americans launched rockets (huge tubes with lots of highly explosive material in it) with astronauts on top of it to the moon and they all came back alive...even Apollo 13...that was first accomplished at the end of December 1968 (Apollo 8 ) till the middle of august 1972 (Apollo 17)...that was nearly 41 years ago...and you guys are now already dying over 12 standoffs? What happend in these ~41 years?
