Vous n’êtes pas connecté.
novax1
Ce message a été modifié 1 fois. Dernière modification effectuée par "novax1" (4 avril 2013, 17:48)
Phatboy69
and to show temperatura.agua information.
sampling and temperature information. external sensor
but the fan out many numbers?.
didnot like show flow.
regards
Ce message a été modifié 2 fois. Dernière modification effectuée par "Phatboy69" (4 avril 2013, 23:41)
I am Intel of Borg. Resistance is futile. You will be assimilated.
Phatboy69
Phatboy69
novax1
Phatboy69
Code source |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 |
<LogDataExport> <name> Alarm </name> <exportTime> 2013-04-07T19:57:59.5025728+10:00 </exportTime> <logdata> <LogDataSet> <t> 2013-04-07T19:57:59.260 </t> <value> 0 </value> <name> Actual alarm level </name> <unit/> <valueType> number </valueType> <device> aquaero 5 </device> </LogDataSet> </logdata> </LogDataExport> |
Phatboy69
Phatboy69
Phatboy69
hello
you changed. Status Icons / Silk 14x14/imagemap.txt?![]()
can set an example. please![]()
thanks
Code source |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 |
; The image map file instructs the SpeedFan Status Image on what image ; file should be displayed for what circumstance. The images listed ; need to be in the same folder. ; ; The format is as follows: ; <Code> <Image File> ; Note that each item is seperated by a tab. ; ; You can miss out any of the codes below and the Status Image will ; try to adapt sensibly. Usually this results in removing a threshold, ; apart from in the case ok leaving out the OK code, in which case no ; icon will be displayed whilst within the desired range. ; NA 0_NA.png ; Icon for when data is unavailable VLO 1_low.png ; Icon for when Value < Very Low LO 2_good_low.png ; Icon for when Value < Low OK 3_good.png ; Icon for when Low <= Value < High HI 4_warning.png ; Icon for when Value >= High VHI 5_danger.png ; Icon for when Value >= Very Low |
Code source |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 |
[Format] type=xml ; xml / txt / ini dataExpiry=0 ; # of seconds to consider the data invalid language=EN ; The language used by the lists in this file. Other languages can be added by copying the lists to a new text file, ; translating them and then saving the file as "lists.<language>.txt", e.g. lists.RU.txt [List:TempStatuses] ; lower bound Short Code Caption NA Not Avail 15 VLO Very Low 20 LO Low 32 OK Normal 40 HI High 45 VHI Very High [Parsing] logdata.LogDataSets logdata.LogDataSets.CpuTime logdata.LogDataSets.CpuTime.*Value logdata.LogDataSet.t logdata.LogDataSets.CpuTime.Level logdata.LogDataSet.t logdata.LogDataSets.CpuTime.Level.Code logdata.LogDataSet.t logdata.LogDataSets logdata.LogDataSets.CpuTemp logdata.LogDataSets.CpuTemp.*Value logdata.LogDataSet.value logdata.LogDataSets.CpuTemp.Level logdata.LogDataSet.value list:TempStatuses,2 logdata.LogDataSets.CpuTemp.Level.Code logdata.LogDataSet.value list:TempStatuses,1 logdata.LogDataSets logdata.LogDataSets.CpuName logdata.LogDataSets.CpuName.*Value logdata.LogDataSet.name logdata.LogDataSets.CpuName.Level logdata.LogDataSet.name logdata.LogDataSets.CpuName.Level.Code logdata.LogDataSet.name logdata.LogDataSets logdata.LogDataSets.CpuUnit logdata.LogDataSets.CpuUnit.*Value logdata.LogDataSet.unit logdata.LogDataSets.CpuUnit.Level logdata.LogDataSet.unit logdata.LogDataSets.CpuUnit.Level.Code logdata.LogDataSet.unit logdata.LogDataSets logdata.LogDataSets.CpuvalueType logdata.LogDataSets.CpuvalueType.*Value logdata.LogDataSet.valueType logdata.LogDataSets.CpuvalueType.Level logdata.LogDataSet.valueType logdata.LogDataSets.CpuValueType.Level.Code logdata.LogDataSet.valueType logdata.LogDataSets logdata.LogDataSets.CpuDevice logdata.LogDataSets.CpuDevice.*Value logdata.LogDataSet.device logdata.LogDataSets.CpuDevice.Level logdata.LogDataSet.device logdata.LogDataSets.CpuDevice.Level.Code logdata.LogDataSet.device |
Ce message a été modifié 2 fois. Dernière modification effectuée par "Phatboy69" (10 avril 2013, 07:15)
Phatboy69
Phatboy69
I am Intel of Borg. Resistance is futile. You will be assimilated.-
