Du bist nicht angemeldet.
sylvainp
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »sylvainp« (27. Juni 2013, 17:54)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »mandrix« (29. Juni 2013, 12:54)
Jakusonfire
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »mandrix« (29. Juni 2013, 16:26)
I don't totally understand basing radiator fan speed on rad in/out delta's ... its the fan's speed that makes the difference to the delta so the fans are being controlled based on themselves somewhat.
sylvainp
Grasshopper
Jakusonfire
In my cooling setup, the rad in/out delta provides a much more immediate indicator of whether or not the system is under load. The water/air delta is a slower and more gradual increase or decrease. Both the rad in/out delta.....and the water/air delta.....are impacted by fan speed, so I'm not sure I follow why you think one makes sense and one doesn't.
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »Jakusonfire« (30. Juni 2013, 04:07)
sylvainp
If you take two identical loops with fixed fan speeds and change the heat load with a GPU benchmark;
The Air/water delta will always change,
while the rad in/out can change briefly with the warmed water hitting the first sensor but once the water goes all the way through the rad the delta drops again, the load is still there but the delta is not.
This graph above shows what I mean. The gap from green to red is rad in/out delta, the Blue to green is GPU in/out
With fixed fans the rad in out stays essentially stable.
At the same time below the Air/water delta of course changes
That is the thing about rad delta's ... they are affected far more by the fan speeds than by anything else, so using them to measure something (like system load) can be troublesome.
But I am asserting that rad in/out delta's change also. And the level of precision that they provide for controller changes far exceeds the level of precision I can get from water/air delta's....simply because of that 1.5 degree fluctuation in ambient room temp every 20 minute central air cycle....where the coolant temp does not respond immediately to the changes in air temp. Your statement about rad delta's being far more affected by fan speeds is not true for my system either. I get similar rad delta's with low speed or high speed on my fans. I think your statement about fan speeds being the largest driver of rad delta's might be true for a system that has inadequate radiator space....but definitely not if you have adequate radiator space.
Grasshopper
If you have multiple radiators with blocks in between ( and remember the pump also adds heat to loop) and place your sensors as Jacusonfire has, you really will see limited fluid temperature, because between each of his 3 sensors he has a heat source and a heat sink.(radiator), the only way Jacus can control his fans is by loop/ambient, his alternative is redesign his loop and changing sensor positions.It's a good discussion....but just continues to prove the point that you really can't make generalizations that hold true for every system. I don't want someone to be steered away from using a rad in/out delta....because depending on your loop, order, radiator space, and external environment.....it may be the best choice by far for you.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Grasshopper« (1. Juli 2013, 02:55)
Jakusonfire
If you have suitable radiator(s) the in/out delta will always change with realistic loads, if sensors are positioned to capture the change. ( I say realistic loads and suitable radiators as a situation of a over kill radiator with lots of air pressure, unacceptable noise levels and a small load will result in limited in/out delta).
The ambient of my sun room changes 17C over a year, so ambient is not for me or I assume many other people a "constant"!!!
so with abstract sensor placement and a climate controlled environment use water/ambient to control your loop.
But if you dont have climate control - position sensors suitably, run your fans at silent speed and control them by in/out delta "is good advise for people in general".
Would be nice to some how tie together in/out delta and ambient, I just cannot dream up a way of doing it , just too many variables.![]()
Corsair H100i
I would imagine it use a single temperature sensor to measure block or fluid temperature with a simple 3 stage "curve". What is most interesting about this style is that Asetek designed them for OEM (5 year life) market, even the tubing has some sort of metal component so that it does not "breath".
Dieser Beitrag wurde bereits 12 mal editiert, zuletzt von »Jakusonfire« (1. Juli 2013, 06:39)
I invite someone to put up a graph showing rad in/out delta changing and holding without fan speed changing.
...measuring from "the hottest part of the loop to the coldest" is hardly the same as rad in out. Measuring hottest part of the loop to coldest is essentially the same as measuring water block in/out ... a completely different thing. By measuring rad in/out you are effectively measuring how much cooling is being done, which will change with fan speed, not how much heating is being done by heat load. If a loop has all the rads together and all the blocks together why would you not just measure straight first block in/ first block out and therefor actually measure load?
How do you make these graph ?
i could not figure it out so far.
Thanks
Jakusonfire
ok.![]()
Just for you...I set my fans all on constant speed controllers, and had them spin at about 900 rpm. It's the purple line at the top, and is the only data element graphed against the right side axis instead of the left. Green area is ambient air...being measure by using an average of two sensors that are both outside the case. Red line is rad in (or hot), and blue line is rad out (or cool). At 12:05 you can see the heat load starts. I ran the Fuzzy-Tessy Donut stress test from EVGA...which puts a large heat load on the system. You can see both the CPU and GPU temps take off at that point. Up until this point...you see the gap between the red and blue line (the rad in/out delta) is very close together. Once the load starts, you see the rad-in temp (red) increase almost immediately....and then the rad-out temp (blue) increases about a minute of two later (after the water has cycled through the radiators). The gap between the red and blue (the rad in/out delta) goes from less than 0.5 degrees celcius...to about 3 degrees celcius....and then stays there as long as the heat load is maintained. I ran it here for 30 minutes just to show you....but it stays the same if I run it for 3 hours.
So this graph represents the rad in/out delta changing when the heatload is applied without fan speed changing. So....now I invite you....to try again in your analysis. You need to give up on your idea that rad delta's only change with fan speed...because I'm proving to you that it's not the case in my system...and you are hearing from other's that it's not the case in their system's either. I'm not going to continue and argue about the same point over and over again...but clearly my experience and data is contradictory to your opinion.
In a loop where you have all your waterblocks together, and all your rads together....then measuring first block in and last block out....is EXACTLY THE SAME THING as measuring the rad in and rad out. The temperature sensors would be in the same places.
Good luck with your system. I don't want to argue with you. I just don't want false information spread.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Jakusonfire« (2. Juli 2013, 23:21)
sylvainp
In a system that is not so ludicrously over capacity this would never happen.
What seems like over capacity to you might be very normal capacity to others. And it wouldn't take as much radiator space as I have in my system...as long as someone had enough radiator space to cool whatever heat load their system generated. So it could even be a single radiator...if they were only cooling one component that didn't generate a lot of heat. You are insisting something is a bad idea...when in fact it can be a very good idea for systems with adequate radiator space. You may define "adequate" at a much lower threshold than I or others do...but that is a totally different argument than whether a rad in/out delta's can change without fan speed changing. They can change...and I've proved that.
......but to recommend it as a superior system for most users is misleading and plain false information.
That is why rad in out delta is a poor system for determining system heat output.
Effectively what your graph shows is that you are actually using a confused form of an air/water delta controller. The rads are so over capacity that the water is returned to ambient temp. So what you are measuring is water to air delta.
.....how is this system any faster or more reactive than a true air/water delta controller. It just isn't. It is the same thing except that at higher temperatures above ambient it becomes corrupted.
