Sie sind nicht angemeldet.
dseg
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »dseg« (29. August 2013, 20:04)
dseg
Grasshopper
Jakusonfire
1. YesI bough the XT model and had a few questions:
1. Do I just connect this straight to my motherboard from the XT unit?
2. Is this the right Cable for the Flow sensor I bought? It says I can extend the cable with a fan cable extension, why can't I just use a fan cable to connect the sensor to the Aquaero? Could I just use the 3-pin aquabus/speed4. cable that looks like it comes with the unit?
3. I am using 2 manual speed controlled pumps which I know can be controlled by voltage with the Poweradjs., what if I get two PWM pumps? Could they just connect to the Aquaero controller and not put a voltage load on the unit (no heat)? Where would they plug in and would I just be able to split one connection to two pumps?
4. How many Gentle Typhoons (D1225C12B5AP-15) can I put on each of the 4 fan channels? I plan to run them about half power which says it is 0.030 A per fan.
5. I wouldn't be using the high and low speed aquabus if I only doing fans and flow sensor, correct? Do I have this diagram correct?
6. What are the differences between the AC D5 and a D5 PWM pump?
7. If I use the manual control D5 pumps, where can i connect the RPM wire so the Aquaero will know if the pump is actually working? (I have two of them).
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Jakusonfire« (1. September 2013, 23:08)
dseg
I've done a couple of guides HERE You should be able to find something there I think to help.....Thank you guys. That was very helpful.
Is there a some kind of guide to setting up the AQ5 with the software?
Right now I trying to setup Alarm Profiles but cannot find anything on this.
Someone had to of made something, I found a good review/guide a few weeks ago but have been searching forever with no luck.
