Sie sind nicht angemeldet.
																		saldot
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »saldot« (14. Oktober 2013, 20:00)
																		saldot
																		saldot
Thanks. Got my gfx block yesterday so took it out since i was rebuilding the loop anyways.I hear ya. I have acrylic tubing and it's definitely time consuming to R&R.
Good luck w/the sensor.
No problem for me, I made and sleeved my own cables for the flow sensors. Distance from the Aquaero's seems to make no difference that I can tell. Just be careful if you make your own cable and wire it correctly....it is NOT the same as a fan cable and you will blow the sensor using a fan cable!Thanks. Got my gfx block yesterday so took it out since i was rebuilding the loop anyways.I hear ya. I have acrylic tubing and it's definitely time consuming to R&R.
If you have 2 of these, have you had any issues with the distance from the flowmeters to the aquaero?
Aquacomputer only has a 30cm cable as does phobya. Have you found anything longer than that? Will be an issue for me when I'll put it back in since it'll be at the bottom of the case while I have the aquaero at the top.
Perhaps you can use a normal 3pin fan cable like this one: ?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »mandrix« (18. Oktober 2013, 10:57)
																		saldot
