Vous n’êtes pas connecté.
Harjan
This is a prototype pcb. You can solder it by yourself.And what kind of splitter pcb's are used in this video of the aquero 6 (http://www.youtube.com/watch?v=DPQaMowIrmU) ? are they also 4pin ? if so where can i find them ?
This is possible, but the fans have no power rating or maximum current. Without this information you cannot calculate the maximum power consumption.Also, will i be able to controll al the fans with PWM control ?
Harjan
Is there any way to buy 4 of these of aquacomputer (for the right amount of money offcourse) ? because i have no knowledge of creating my own splitter pcb.This is a prototype pcb. You can solder it by yourself.And what kind of splitter pcb's are used in this video of the aquero 6 (http://www.youtube.com/watch?v=DPQaMowIrmU) ? are they also 4pin ? if so where can i find them ?
So if i got 2 pumps connected to the aquabus and the fan channels like below, it should work fine on the aquero 6 xt without the need of any accessoires ?This is possible, but the fans have no power rating or maximum current. Without this information you cannot calculate the maximum power consumption.Also, will i be able to controll al the fans with PWM control ?
When you use the aquabus D5 pumps. You can use 9 fans at each fan output.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Harjan" (14 novembre 2013, 18:21)
Jakusonfire
Ce message a été modifié 1 fois. Dernière modification effectuée par "Jakusonfire" (14 novembre 2013, 19:31)
Harjan
What about where to buy the blanco PCB's ?No.Is there any way to buy 4 of these of aquacomputerWithout the electric specification from the fan we cannot say if your setup will work.should work fine on the aquero 6 xt without the need of any accessoires ?
According to this review on the Akasa site;
http://tech-reviews.co.uk/reviews/akasa-120mm-apache-fan/3/
the fans use 0.33 amp each
16 of them on a channel is 5.28 amps ... just a little bit excessive for an Aquaero. Even 8 per channel would be pushing the capabilities I believe.
By way of contrast a similar speed corsair SP120 uses 0.08 amp
A build on a scale like this requires a fair bit of knowledge and skill. There aren't just commercial splitter PCB's to accommodate 16 fans because practically no one would buy them. In similar builds people usually create custom wiring harnesses themselves.
In this case if you want to do it you would need to wire each fan direct to the power supply and also run PWM and speed signal wires from each channel of the Aquaero to each bank of fans. That way the Aquaero is not powering the fans and there should be no effective limit.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Harjan" (15 novembre 2013, 05:25)
Is an normal prototype pc like this:What about where to buy the blanco PCB's ?
Normaly you can control the fans with volatge over a better rpm bandwidth.Also what is the advantage of pwm vs 3-pin on the aquero 6 ?
Harjan
http://www.thelittlebritishrobotcompany.…t&product_id=75
With voltage control you can slow down the fans more in the most cases.
Ce message a été modifié 4 fois. Dernière modification effectuée par "Harjan" (15 novembre 2013, 15:22)
