 31.10.2025, 06:16
31.10.2025, 06:16 Change Language
 Change Language
						 Register
 Register Login
 Login
											You are not logged in.
																														 LossMentality
																		LossMentality
								Saturday, November 23rd 2013, 9:07pm
																														 LossMentality
																		LossMentality
																														 pegleg
																		pegleg
This post has been edited 1 times, last edit by "pegleg" (Nov 30th 2013, 9:33am)
																														 pegleg
																		pegleg
I do not see flow 11 or 14 just flow 1&2 aquasuite 2013-5 keeps crashing on me done it twice 2 me just taken screen shots.everytime i click mps will crash.When your MPS Device is connected via aqaubus with the aquaero you to add the flow sensor source from mps device to your sensor settings.
The MPS has the sensor numbers Flow 11 .. 14.
This post has been edited 2 times, last edit by "pegleg" (Dec 1st 2013, 1:12am)
																														 pegleg
																		pegleg
This post has been edited 2 times, last edit by "pegleg" (Dec 1st 2013, 9:25am)
																														 LossMentality
																		LossMentality
																														 pegleg
																		pegleg
yes ,i should be able 2 setup the mps when connected to usb and see the flow 11 or 14 right,or do i have to unplug the usb and then i will see it ?The aquabus provide the most sensor values/ device data from each device.
The aquaero can only use data from other devices when the device is connected via aquabus.
The usb connection for all devices is only for the aquasuite software (display data and setup device).
This post has been edited 1 times, last edit by "pegleg" (Dec 2nd 2013, 7:30am)
 English forum »
 English forum » Aquaero 5 XT controller unit not detecting my high speed flow sensor (53129)
											(Sep 16th 2013, 5:45am)
										 English forum »
 English forum » PowerAdjust and MPS on same aquabus ?
											(Jan 16th 2013, 10:42am)
										 English forum »
 English forum » Linking Aquaero 5 XT and LT in Aquasuite 2012
											(Aug 21st 2011, 9:15am)
										 English forum »
 English forum » Aquasuite 4.72 flow sensor question
											(Jun 12th 2011, 6:53pm)
										 English forum »
 English forum » Aquaero + Flow sensor intermittent flow data
											(Nov 17th 2010, 3:08am)
