Vous n’êtes pas connecté.
Bytales
avictord
By Power Hub I meant this setup for example (see link). Bitspower X-Station comes in varying sizes and are set up to reduce power cables. You mentioned connecting Fans directly to power and the PWM to the Aquaero. This type of hub would also provide power to the PA3's and the XT itself.... Anyway just some feedback.What do you mean by Power Hub ? Which Deltas do you mean !
Regarding the USB Connection to the Computer i think i might have found the solution
Through this adapter:
http://www.bitfenix.com/global/en/produc…l-usb3-adapter/
im going to connect two of these:
http://www.hubgear.com/usbg-7u3ml.php
The Hubs will give me in total 14 USB slots, and since i will need 11, i will be left with 3 spare.
The hubs im going to stick with double Adhesive thape inside the case, their thickness is small enough to fit inthe back of the STH10 case.
And maybe i wont even need to power it, if im going to connect only the stuff from AquaComputer to them.
6 for PA, 2 for Pumps, 2 for Flowmeters, 1 for AquaAero.
1 for Bluetooth, 1 for Wireless Headset, and i still got one free just in case.
The only thing that remains is to make my own custom lenght USB cable with USB connector on one side and DUpont 5 pin connector on the other side.
Im ordering the required parts from ModDiY to be able to make my own custom lenght USB cable.
I could have used this one here for more USB slots,
http://www.hubgear.com/usb3-16u1.php
but it is beeing connected through only one USB cable, which means 16 ports thorugh a single usb cable. But i have 2, which means 7 port per cable instead of 16, it might even work without additional power.
Bytales
Dagamus(NM)
Bytales
I stil need to figure out the 3 pins of the PA3s Aquabus connectors, which ones are in relation to the 4 pins the aquabus has on aquaero.
Probably pin 4 is missing, and pin 1 is the one on top.
Ce message a été modifié 3 fois. Dernière modification effectuée par "EnigmaG" (16 février 2015, 15:47)
Bytales
How do i set the aquabus adress for each device ? in the aqua suite software, or somewhere in windows ?
Since i own poweradjusts 3, and not 2, i need to ask if there is an online manual for the 3 version. I suppose that pin number 1 is the pin on top, and 3 the pin on bottom.
Ce message a été modifié 2 fois. Dernière modification effectuée par "EnigmaG" (18 février 2015, 00:48)
Bytales
