You are not logged in.
Bytales
This post has been edited 1 times, last edit by "Bytales" (Mar 7th 2015, 6:29pm)
Bytales
Yes, I believe you just keep adding Y-connectors until all your devices are connected.
The only issue I can detect is that you have 4 pumps (2 compact 600 & 2 aquastream xt), but there are only 2 aquabus addresses (10 & 11) available for pumps.
I think the 2 flow sensors & the 2 aquainlets will use the 4 MPS addresses (12, 13, 14, 15), and there are 8 addresses available for the 6 poweradjusts.
This post has been edited 1 times, last edit by "Bytales" (Mar 7th 2015, 6:23pm)
Bytales
Quoted
7.4. Connector “aquabus/flow”
Connector for communication with other Aqua Computer devices. For versions
Standard and Advanced, the connector “aquabus/flow” is configured as an
aquabus interface and can be used for instance to connect the pump to an optionally
available aquaero fan controller. For these variants, a flow sensor must
not be attached to this connector!
You can use the aquabus/speed signal cable included in delivery to connect the
pump controller board to a suitable connector of a compatible device, for example
an aquaero. USB and aquabus interface can be used at the same time,
however not all control options of the aquastream XT are available using the
aquabus interface.
If this connector is connected to an aquabus device, the port must not be configured
as flow sensor input! Otherwise, the pump controller will be destroyed and
all guarantees will be void!
For the Ultra variant, this connector can be configured for two different functions.
Default configuration of this connector is an aquabus interface. Using the aquasuite
software, this connector can also be configured to be a flow sensor input.
Simultaneous use of the aquabus and flow sensor function is not possible! Please
see chapter 14.4. for details on configuring the desired function.
Flow sensor and special interconnecting cable are optional accessories and not included
in delivery.
Pin assignment: Pin 1: GND
Pin 2: aquabus SDA / flow sensor +5 V
Pin 3: aquabus SCL / flow sensor signal
Compatible aquabus devices:
● aquaero 5 XT (art. 53125 and 53089)
● aquaero 5 PRO (art. 53090)
● aquaero 5 LT (art. 53095)
Compatible flow sensors:
● Flow sensor with 5.6 mm nozzle (art. 53061)
● Flow sensor “high flow” (art. 53068)
● Connection cable for flow sensor (art. 53027)
Bytales
Bytales
i took a look at the compatible flow sensors that can be attached to the 3 pin connection, and its not the ones that i have. So that means i will use the 3 pin connector to attached it to the aquabuss. i will wire a y/connection to the last port of the last PA, to connect the 2 pumps, as thei also have 3 pin aquabus.
This post has been edited 1 times, last edit by "Bytales" (Mar 8th 2015, 6:52pm)
Bytales
This post has been edited 1 times, last edit by "Bytales" (Mar 15th 2015, 10:54pm)
