Vous n’êtes pas connecté.
One other minor item, and it may be by design, Windows Services is disabled by default with 2015/9.
).Very unlikely that this has something to do with the aquasuite. It is more likely that it is the aquaero directly. Te AI Suite seems to "optimize" some USB stuff but in reality it is breaking it (like always...).
As you already said, you are not the first one having problems with this combination. In another Forum I have read that leaving out some processing stuff seems to fix it. I do not know that software but it seems that there are different modules that you can install or not.
2015-9 page display is very, very slow for me, for example as in switching between my 2 pages within Aquasuite. Also labels are often not showing up unless I close/reopen Aquasuite several times. It's not only the software data from AIDA64 Extreme, but the actual data from the Aquaero's as well. (fan speed, temperatures, etc.)
Otherwise everything working well.
Anyone else seeing this?
I am not experiencing any slow down compared to the previous release (2015/6), and am not seeing anything of the errant labels.
Just curious, your post on the 13th in this thread said you were using HWiNFO, and now you are using AIDA64. Though that should not impact the labels issue, it may affect the response of updating the objects. I found the shared memory function of HWiNFO to be more responsive than the WMI function of AIDA64. On the face of it, it shouldn't matter too much because both were set to a 2000ms sample rate, but when I had 2 gauges next to each other, the HWiNFO gauge seemed more active.
Make screenshots from the slow and wrong redered pages. Otherwise send us your comlete data folder as a zip fileThe missing labels are hit and miss, sometimes no problems other times it is. But opening pages in Aquasuite is consistently slow for me, averaging 8 or 9 seconds.
					Code source |
					1  |
					C:\ProgramData\aquasuite-data  |
Code source
 1 C:\ProgramData\aquasuite-data
give us some information about your system. have you changed the font scaling to a other value than 100% in your screen settings?
