• 15.11.2025, 03:10
JasonMorris
My Aquaero 6 Pro shows the wrong time
Monday, November 30th 2015, 10:17pm
The time on my pc is correct and in the Aquasuite software it's fine (see attachment) but the display on the unit is always an hour ahead. Firmware is v2400 and Aquasuite v2015 release 9. Running under Windows 7 64bit. Unit is connected via USB only.
Any ideas?
thanks.
JasonMorris has attached the following file:
  • Aquaero 6.jpg (22.92 kB - 138 times downloaded - Last download: Sep 28th 2025, 6:01pm)
Tuesday, December 1st 2015, 11:55am
Make sure that your Windows configuration is using the correct time zone. The correct time alone will not be enough because the time zone also plays an important role here.
JasonMorris
Sunday, December 6th 2015, 10:46am
The Windows timezone is correct (London) so what should the timezone be on the Aquaero 6 please Shoggy?
thanks
Sunday, December 6th 2015, 12:12pm
you have to set the timezone in the aquaero to your local settings -> London == 0, in your setup i see "+1" (Berlin)
JasonMorris
Sunday, December 6th 2015, 7:47pm
Perfect Shoggy. Many thanks :)
Similar threads
