• 25.10.2025, 19:54
The Asgard
RGB LED stopped working after firmware update
samedi 26 mars 2016, 08:55
Hi there,
I have a Aquaero 5 XT and just upgraded to the new aquasuite 2016-3. After the upgrade it said I needed to upgrade the firmware. Everything worked fine apart from the RGB led appears to have stopped working. I have tried everything including a factory reset. Any ideas?
Other option is to downgrade the firmware and go back to the old aquasuite?
Many thanks
samedi 26 mars 2016, 14:31
Might be helpful to provide a screenshot of the controller and outputs tab.
A downgrade is not possible.
The Asgard
samedi 26 mars 2016, 20:26
Hi Shoggy,
Thanks for having a look at this.
If you need any more things give me a shout.
Many thanks
The Asgard a envoyé les fichiers suivant :
  • Controller.JPG (211,99 kB - téléchargé 122 fois - Dernier téléchargement : 23 octobre 2025, 17:10)
  • Outputs.JPG (152,43 kB - téléchargé 106 fois - Dernier téléchargement : 23 octobre 2025, 02:38)
The Asgard
samedi 26 mars 2016, 22:07
OK problem sorted.
It appears the black common had come away from the RGB LED. Must have been on the verge. Just weird it happened when it did.
Working fine now. Many thanks
Discussions similaires
