Vous n’êtes pas connecté.
only the lastest version of aquasuite is available.
maximus61
I need an older version because the data in the aquaero will be wiped out if I change to the latest firmware supported by the aquasuite 2016 version.
I don't wan't to create a whole new setup. And my current aquasuite 2013 don't work with Windows 10. I hoped if I had a 2015 version I might make it work with windows 10 without had to delete my data in the aquaero 5.![]()
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (11 mai 2016, 22:59)
I do not know if the aquaero 4 works with aquasuite 2016... vendor rep can advise.
Staring with aquasuite 2016, the program automatically saves the current aquaero profile to disk before updating the firmware.
Then after the firmware and aquasuite update, you just reload your profile from disk, and all settings should be as before..
The aquaero 3.07/4.00 can be only used with aquasuite 4.72.
The automatic save for the aquasuite 2016 only works if the data in the device is compatible (the aquasuite will tell if this is the case or not). Since it seems that he wants to do a pretty huge version jump I have some doubts that the data in the device will be compatible to the current aquasuite.
maximus61
Ce message a été modifié 1 fois. Dernière modification effectuée par "maximus61" (13 mai 2016, 14:18)
a normal setup with all options from the factory defaults is done in less than 20 minutes. When you know what is important for your setup in 5 min.Yes, you got my point. I cannot use aquasuite 2016 on my aquaero 5 , without upgrade my firmware. If I do that, all my data will be gone couse it is not compatible. Thats why I would like an older version then 2016
Thx![]()
maximus61
Thx![]()
