Sie sind nicht angemeldet.
Bytales
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Bytales« (26. Mai 2016, 21:39)
Bytales
Bytales
That green "stuff" or residue is signs of growth. You will need a complete tear down and clean out all your parts.
How long have you had this loop?
When's the last time you did maintenance? Flush? Annual break down and clean?
Did you have any biocide in the loop?
What fluids were you using?
Bytales
Yes! Silver is a biocide. You'll need to do a complete tear down, shake the heck out of the radiators with warm soap because they have a ton of hard to reach places and then rinse it all out a few times with distilled and start over on a clean slate. That also includes your blocks, reservoir, clean out the pumps and throw away the tubing and replace it with some PrimoChill Advanced LRT. Get a silver kill coil and you should be set.
A set of rules me and a few experts go by in the H20 world in another forum is, we recommend a reflush of the liquids every 6 months and a break down every 12 months or annually. That's if you want your parts to last. There are others that went on for 3 years with distilled and silver kill coil as biocide and had no issues. Sometimes that can happen but why take the chance in case something happens right? In my case some parts are new but most are about 5 years ago. My loop taken apart looks good as new other then some oxidized spots.
Bytales
Bytales
