Du bist nicht angemeldet.
dayday
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »dayday« (9. Oktober 2016, 14:58)
Hi guys
I brought a flow sensor (53068 ) and a Phobya flow meter cable 3-pin 80cm - black sleeved, I've connected it to the flow port/header on my Pro 6 but its not shown up in the Aquasuite, is there anything else i need to enable etc...
Thanks Day
dayday
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »dayday« (9. Oktober 2016, 17:11)
Thanks for the reply, I've done some research and I know it should show up under senors but its not showing... (image attached)
http://imgur.com/kcV4G8e
any ideas??
Thanks Day
any ideas??
Thanks Day
Have you tried clicking on the white "Flow 1" or "Flow 2" areas and seeing if a setup function shows up?
dayday
Thanks for getting back to me I have done the following and it was showing up on the display but I was still getting no reading.I have the same flow sensor. Works great.
Under "Informations pages" tab, you need to go under flow sensors and add "Flow Sensor 1" to display on your Aquaero itself.
As far as showing up in the software, I have no clue and that would be new to be if it was possible.
Yes it does show up, but I do not know how to configure it, any help please?Thanks for the reply, I've done some research and I know it should show up under senors but its not showing... (image attached)
any ideas??
Thanks Day
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »dayday« (10. Oktober 2016, 10:02)
dayday
Thanks Shoggy everything mentioned is spot on the fan ran and I got a reading I'm not sure what is faulty has I brought everything at the same time, I will RMA the flow meter keep the cable and also buy another cable just in caseFor a simple test of the aquaero you could connect a not so power hungry fan to the flow port. It will be powered with 5V and should run. In this case it should also provide a rpm signal so the flow should show some (weird) value. If this is the case it is pretty safe to say that either the flow sensor connection cable is not OK or the sensor itself is faulty.
