Du bist nicht angemeldet.
saldot
Upgraded my computer a few weeks ago and moved the watercooling parts to the new computer.
Previously I had my pump connected using both aquabus (to a aquaero 5LT) and USB but in the new computer i've used only aquabus and it has worked for a few weeks.
Yesterday evening the pump never started when I booted my computer and the only way to get it working was connecting it using USB.
Any idea why the pump would stop working over aquabus all of a sudden?
Parts used:
Aquaero D5 USB, aquaero 5 LT USB, Flow sensor high flow G1/4 for aquaero & aquacomputer inline temp sensor.
saldot
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »saldot« (1. März 2017, 23:47)
saldot
I don't know which version of Aquasuite you're running, but in the 2017 versions, after you change a value of a component, on the left side of the window a "disk" symbol appears in the top bar for that device.
That indicates that the change must be saved to the device.
If the change is not saved, upon restart, the device will revert to the last saved or default value.
RodeoGeorge
saldot
saldot
I'm beginning to suspect the pump is broken or soon to be broken.
Tried connecting it over USB only. Same issue, pump doesn't start when I power on the computer. Afaik, the pump should start as soon as it gets power and run at the speed that was previously set. Should work even if no cables (usb or aquabus) are connected... right?
saldot
