You are not logged in.
lovan6
This post has been edited 4 times, last edit by "GTXJackBauer" (Mar 14th 2017, 6:54am)
My air sensors don't heat up since they're on the intake side of the rads and fans.
Radiant heat effect is distance dependent, not air temperature dependent.
Think of the Sun heating the Earth with a vacuum between the two.
This post has been edited 1 times, last edit by "GTXJackBauer" (Mar 15th 2017, 4:41am)
Oh, and the damned pumps (2 Aquastreams, 1 Ultima and 1 XT). I got my brother in law to make an acrylic plate wich I mounted on those yellow rubber screws, and I even put a 2,5cm stub of rubber hose after the outlet of the pumps (I use plastic tubes and they carry vibration), but even so, the vibration from the pumps, even at 3000rpm, is notcable, not bad, even at max they aren't too bad, but it's definately the noisiest thing inside the caboinet, on reasonable normal use (turning the fans up to max will make more noise, but mostly from the wind they generate).
