• 25.04.2024, 01:00
Aquabus D5 and 6XT regulation
Freitag, 28. Juli 2017, 00:16
I would like to advise how to regulate this pump. I plugged it into the highflow connector in the aqua6xt if I click to pump in aquasuite - nothing to change and the pump goes still at 3000rpm. Any info what am I doing wrong? I dont have pluged USB cable.
Thanks. :huh:
EDIT: Here is image: http://i.imgur.com/mPkZsWv.png if i slide slider anyhow still the same speed.
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »racecar« (28. Juli 2017, 00:33)
Montag, 31. Juli 2017, 04:53
Becuase as the image shows you have the minimum speed set to 68% and the maximum to 100%
Setting the preset slider to 6% makes the pump run at 6% of the range from 68 to 100 which is 71. If you set min to 50% and max to 80 with the preset to 50% the pump will run at 50% of the range between 50 and 80 which would be 65%
If you set the min to 0 and max to 100 you will get the full range of control
Montag, 31. Juli 2017, 14:56
Of course, I understand, but rpm does not change when i slide with the sliders anyway.
http://i.imgur.com/1XVz3c1.png
Mittwoch, 2. August 2017, 11:10
You have to setup the Bus Priority to aquabus in the system tab. To edit this you have to connect the pump via USB.
Mittwoch, 2. August 2017, 12:44
Many thanks.
It works well. ^^
