You are not logged in.
																		zerophase
																		zerophase
This post has been edited 2 times, last edit by "zerophase" (Dec 16th 2017, 2:58am)
																		Dundys
Quoted
If you have one AC item that qualifies for the latest AS version, you are good to go for all AC items.
If you installed the latest version of AS, you probably had to do a firmware update to the aquaero.
If so, you will need to do a firmware update to all AC devices on the aquabus.
Once all devices are firmware updated, you should implement the following procedure:
1. shut the computer down
2. turn the PSU off
3. unplug the PSU mains cable
4. wait 1 minute for all components to fully drain
5. plug in the PSU mains cable
6. turn on the PSU
7. turn on the computer
optional: take a prayer stance
I really like that 1
Quoted
																		zerophase
I recently flushed the system, so it might start working. That being said I'm still going to get a replacement just so I don't need to drain the loop in case the thing is dead.
Going to run it through some Mayhems Blitz part 2. Is there anyway to mock test the device? Just to verify if it still works, without placing it in the loop.
Overall, it took two years for the pastel coolant to kill the device. I'll still be using pastels in the future with it.
