Recently finished building my first custom cooling loop with a Aquacomputer D5 pump. So far I got to say I'm loving the AquaSuite software and having all my sensor data in one nice spot with easy to setup readouts. There are things I wish it did better however such as having an adjustable sensor sampling rate. I use HWinfo64 v5.24 to pull sensor data, and when viewing the data on HWinfo the data is presented live. However when I set up my AquaSuite page it only shows updated data every 5 seconds. 5 seconds is an eternity in the computer world and when trying to see CPU/GPU core utilization or SSD usage a lot can happen in 5 seconds. Is there a setting somewhere that can adjust this sampling rate? I took a look in the registry and for any INI/Config files that I could adjust and found nothing. Even ASUS horable AI Suite software shows real time data. I know having multiple sensor software running at the same time can cause issues. So I only have HWinfo64 and Aquasuite auto starting. everything else is either uninstalled or not set to auto start. Any help would be great!!!
[img]https://drive.google.com/open?id=0B3q6jVr3MvHFTVdqYUw5QlRlb0k[/img]
System Specs:
CPU: AMD 9590
MB: ASUS Crosshair V Formula-Z
RAM: Corsair Dominator DDR3 16GB
GPU: ASUS Strix 390 8GB OC Edition
SSD: Samsung 850 Pro 256GB
HHD: WD Raptor 10K 300GB
PSU: Corsair AX1200i
CASE: Caselabs Merlin SM8
FANS: Corsair AF120 (3)
Cooling Specs:
CPU: EK Supremacy
PUMP: AquaComputer D5 USB
RES: Monsoon MMRS
RAD: XSPC AX480
FAN: Corsair SP120 (4)
TUBE: Monsoon PETG 1/2"
Fittings: Promochill/Bitspower
Coolant: DS Water w/ Primochill Utopia
